Re: @version tag auto-filled with revision number [message #287136 is a reply to message #287114] |
Fri, 24 June 2005 14:57 |
Originally posted by: bradley.wagner.hannonhill.com
Thanks, that's exactly what I was looking for. Do you know if there's anyway to make the time print
out as local time as opposed to GMT. I noticed that while if I view the Resource Historoy in Eclispe
it displays the local time, the CVS info is always in GMT.
Horváth, Csaba wrote:
> Because java source files are plain text files you can use all CVS-related
> keywords.
> In Preferences > Team > CVS page set 'Default keyword substitution' to
> 'ASCII with keyword expansion (-kkv)'.
> After this setting you can use all $xx$ CVS keywords. For revision numbers
> you can use '@version $Revision: $
> You can use all CVS keywords:
> http://www.badgertronics.com/writings/cvs/keywords.html
> HTH,
> Csaba
> Bradley Wagner wrote:
>>Is there a way using Eclipse and CVS to autofill the @version Javadoc tag
>>with the CVS revision number of the file? Sun's documentation on @version
>>tag mentions this sort of autmation:
>> http://java.sun.com/j2se/javadoc/writingdoccomments/index.ht ml#@version
>>Thanks,
>>Bradley
Re: @version tag auto-filled with revision number [message #287153 is a reply to message #287114] |
Fri, 24 June 2005 20:18 |
> keywords.
And you can then wirte your own Javadoc version tag so that it gets
formated right in the html output.
Re: @version tag auto-filled with revision number [message #287156 is a reply to message #287153] |
Fri, 24 June 2005 20:41 |
How?
>>keywords.
Re: @version tag auto-filled with revision number [message #287177 is a reply to message #287156] |
Sat, 25 June 2005 10:26 |
http://java.sun.com/j2se/1.4.2/docs/tooldocs/javadoc/overvie w.html
and use ant and not the command line
> How?
>>> CVS-related
>>> keywords.
>>> numbers
FUDForum. Page generated in 0.03103 seconds
