Home » Eclipse Projects » Eclipse Platform » Cocoon ant build
Cocoon ant build [message #28678] Wed, 07 May 2003 14:37 Go to next message
Originally posted by: fessler.cs.montana.edu
I'm just learing about cocoon, and while reading about it i found a
little website with almost enough information to show me how to turn it
into an eclipse project. So, i have cocoon running as an eclips
project, but the ant build fails. Here is the output from the console.
Basically it seems like it is looking for files in my home directory
instead of the cocoon directories. What I can't figure out is how to
make ant look in the right directories. I can run the ant build just
fine from command line in the cocoon directory. I'm certain there is
something simple i'm missing.
Thanks for you assistance and patience.
--marc
Buildfile: /usr/local/cocoon-2.0/build.xml
init:
[echo]
[echo] Apache Cocoon 2.2.D11 [1999-2003]
[echo]
[echo] Building with Ant version 1.5.1 compiled on October 2 2002
[echo] using build file /usr/local/cocoon-2.0/build.xml
[echo]
[echo] WARNING:
[echo] This build is targeted for use with JVM 1.4
[echo]
[echo] Using this build on a virtual machine other than the
one
[echo] it is targeted for may result in runtime errors.
[echo]
[echo]
optional-tests:
bsf-warn:
rhino-warn:
jfor-warn:
xmldb-warn:
xt-warn:
php-warn:
op-warning:
[echo] **********************************************
[echo] *
[echo] * Classes of the optional package PHP are not
[echo] * available. Apache Cocoon builds without them.
[echo] *
[echo] * PHP is required for the php generator.
[echo] *
[echo] * Recovery:
[echo] * Get the PHP servlet (phpsrvlt.jar) from
http://www.php.net/ and place the jar in the lib/optional dir
[echo] *
[echo] ***********************************************
naming-warn:
op-warning:
[echo] *
[echo] * Classes of the optional package JNDI are not
[echo] *
[echo] * JNDI is required for the ldap generator and the
parentcm generator.
[echo] *
[echo] * Recovery:
[echo] * Get the jndi.jar from Sun and place the jar in the
lib/optional dir
[echo] *
svg-warn:
fop-warn:
tidy-warn:
maybeupload-warn:
lucene-warn:
deli-warn:
velocity-warn:
hsqldb-warn:
resolver-warn:
jisp-warn:
pizza-warn:
poi-warn:
commons-logging-warn:
optional-warnings:
prepare:
generate-java-code-check:
generate-java-code:
filter-jdbc:
nofilter-jdbc:
prepare-jdbc:
prepare-src-main:
[roles-tool] Reading:
/home/marc/build/cocoon/src/org/apache/cocoon/cocoon.roles
[roles-tool] BUILD FAILED: file:/usr/local/cocoon-2.0/build.xml:909:
IOException: java.io.FileNotFoundException:
/home/marc/build/cocoon/src/org/apache/cocoon/cocoon.roles (No such file
or directory)
Total time: 19 seconds
Re: Cocoon ant build [message #29846 is a reply to message #28678] Mon, 12 May 2003 15:14 Go to previous message
Set the basedir of the Ant build file to be the cocoon directory. That is
essentially what you are doing when you run the Ant build from the command
You may have to alter other aspects of the build file to be properly
relative to the {$basedir} property.
The base directory can be set on the Main tab of the Ant launch
configuration dialog.
HTH
Darins
"Marc Fessler" <fessler@cs.montana.edu> wrote in message
news:3EB95254.9060007@cs.montana.edu...
> --marc
> init:
> [echo]
> [echo]
> [echo]
> [echo] WARNING:
> [echo]
> one
> [echo]
> [echo]
> optional-tests:
> bsf-warn:
> rhino-warn:
> jfor-warn:
> xmldb-warn:
> xt-warn:
> php-warn:
> op-warning:
> [echo] *
> [echo] *
> [echo] *
> [echo] * Recovery:
> [echo] *
> naming-warn:
> op-warning:
> [echo] *
> [echo] *
> parentcm generator.
> [echo] *
> [echo] * Recovery:
> lib/optional dir
> [echo] *
> svg-warn:
> fop-warn:
> tidy-warn:
> maybeupload-warn:
> lucene-warn:
> deli-warn:
> velocity-warn:
> hsqldb-warn:
> resolver-warn:
> jisp-warn:
> pizza-warn:
> poi-warn:
> optional-warnings:
> prepare:
> generate-java-code:
> filter-jdbc:
> nofilter-jdbc:
> prepare-jdbc:
> prepare-src-main:
> or directory)
Previous Topic:Eclipse 2.1 OutOfMemoryException WinXP prevents startup
Next Topic:Porbs with auto-merge of jsp's in eclipse CVS
Current Time: Sun Nov 02 19:14:21 EST 2025
Powered by FUDForum. Page generated in 0.03975 seconds
