Home » Eclipse Projects » Eclipse Platform » Ant M7
Ant M7 [message #285688] Mon, 23 May 2005 10:45 Go to next message
After installing the M7 version, I cannot get any of my previous ant
scripts to run. There is no error logged. All I am getting is an error
from the JVM saying that the main class cannot be found. I am using ant
1.6.4 (setting a different ant home), and checked the ant.jar MANIFEST.MF
file, and the main class is set correctly. I am running J2SDK 1.4.2_07.
Chris
Re: Ant M7 [message #285695 is a reply to message #285688] Mon, 23 May 2005 12:36 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=95611
To workaround this problem in M7, you can turn off "Set an Input Handler" on
the Main page of the Ant launch configuration OR run your build in the same
JRE as Eclipse (see the JRE tab)
HTH
Darins
"Chris Corridoni" <corridcm@wyeth.com> wrote in message
news:a650cf2f84bf3c75d608e9c5468d166c$1@www.eclipse.org...
> Chris
Re: Ant M7 [message #285703 is a reply to message #285695] Mon, 23 May 2005 15:01 Go to previous message
Thanks, it did help.
Chris
> HTH
> Darins
>> Chris
Previous Topic:WHY ClassNotFoundException: derby is declared as a dependency/required plug-in already
Next Topic:UI conventions for error marking in multi-page editors?
Current Time: Thu Apr 17 04:18:45 EDT 2025
Powered by FUDForum. Page generated in 0.04301 seconds
