Home » Eclipse Projects » Eclipse Platform » JUnit Plugin Test No-Longer runs in M7
JUnit Plugin Test No-Longer runs in M7 [message #285534] Wed, 18 May 2005 10:41 Go to next message
Originally posted by: alfiewong.gmail.com
After migrating from M6 to M7 my JUnit Plugin test no longer run. I get
the following error everytime I run a Plugin test.
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.NoClassDefFoundError:
org/eclipse/jdt/internal/junit/runner/RemoteTestRunner)
at org.eclipse.swt.SWT.error(SWT.java:2691)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:161)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:25)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:3096)
org.eclipse.ui.internal.testing.WorkbenchTestable.runTest(Wo rkbenchTestable.java:83)
org.eclipse.pde.internal.junit.runtime.UITestApplication.run Tests(UITestApplication.java:97)
org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:56)
at java.lang.Thread.run(Unknown Source)
I'm not sure why this occurs but any help would be appreciated. All I did
to migrate over was point M7 to my M6 workspace.
Re: JUnit Plugin Test No-Longer runs in M7 [message #285546 is a reply to message #285534] Wed, 18 May 2005 13:13 Go to previous messageGo to next message
Originally posted by: ya_xiang.hotmail.com
junit plugin-test works well.
what you need just is a clean eclipse.
Regards.
xiangya.
"Alfred Wong" <alfiewong@gmail.com> ????
news:ef38c15e6c9b726a8a7544b27d015d9b$1@www.eclipse.org...
> at
java:83)
> at
ication.java:97)
> at
va:56)
Re: JUnit Plugin Test No-Longer runs in M7 [message #285552 is a reply to message #285546] Wed, 18 May 2005 21:28 Go to previous messageGo to next message
I have a similar problem in M7:
!ENTRY org.eclipse.osgi 2005-05-18 21:11:37.445
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException[1]:
java.lang.NoClassDefFoundError: org/eclipse/ui/testing/ITestHarness
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.defineClass(DefaultClassLoader.java:322)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:223)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findClassImpl(DefaultClassLoader.java:305)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findClass(DefaultClassLoader.java:197)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:179)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:137)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:118)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:74)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1259)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:152)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:371)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:160)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:330 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:274)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
In M6, it worked. I have cleared and reimported all eclipse plugins.
Problem is still there. I once had a similar problem, the cause was a
missing runtime plugin. But this time I am a bit puzzled.
I added org.eclipse.ui.workbench containing ITestHarness which was not
found to my plugin dependencies (just a shot in the dark) and included
it in the runtime config but no success.
Any ideas?
Ingo
xiangya wrote:
> Regards.
> xiangya.
>>at
> java:83)
>>at
> ication.java:97)
>>at
> va:56)
Re: JUnit Plugin Test No-Longer runs in M7 [message #286068 is a reply to message #285534] Wed, 01 June 2005 14:18 Go to previous message
Did anybody get this working?
Alfred
> at
> at
> at
> at
> did to migrate over was point M7 to my M6 workspace.
Previous Topic:Welcome page introContent
Next Topic:Ant extension
Current Time: Mon Oct 27 06:26:42 EDT 2025
Powered by FUDForum. Page generated in 0.04266 seconds
