Home » Eclipse Projects » Eclipse Platform » KeyBinding service w/multi type editor
KeyBinding service w/multi type editor [message #28506] Tue, 06 May 2003 15:10
I have a multi-type editor where each editor requires a different set of
key-binding services. The problem is that the bindings are incompatible
with each other. When the focus is switched between the two, how do I
tell the key binding service to use a different set of scopes/registered
actions. Since the key binding service is instantiated only at the
editor site level, I don't see anyway to do this.
Thanks, Rich Kulp
Previous Topic:Creating a new Java Project ...
Next Topic:Can't get the Output from IProcess
Current Time: Fri Apr 25 00:30:45 EDT 2025
Powered by FUDForum. Page generated in 0.02370 seconds
