Home » Eclipse Projects » Eclipse Platform » Dirty editor
Dirty editor [message #284792] Mon, 02 May 2005 07:30 Go to next message
Originally posted by: jsridhar.sdf.lonestar.org
I have the following situation. I have an editor where an object in a view
is opened for editing. The user makes some changes to the object, and then
decides to close the editor. At closing, he is asked whether to save the
object and if the user chooses No, I need to determine this. When the user
answers Yes, the workbench invokes doSave() at which point the object can
be saved. But when the user answers No, I need to find this out so I can
reload the object (since it is dirty and the user has indicated that he
does not want to keep the changes).
I looked around but could not find anything of relevance.
Thanks in advance
Re: Dirty editor [message #284811 is a reply to message #284792] Mon, 02 May 2005 14:20 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
Why do you need to do this? The editor is closing; if it is reopened
later, it will reload the object.
If the issue is that you have something other than the editor using the
same contents, the solution is: when all editors for the object close,
stop using the document contents and start using the resource contents
(from disk).
Bob Foster
> view is opened for editing. The user makes some changes to the object,
> and then decides to close the editor. At closing, he is asked whether to
> save the object and if the user chooses No, I need to determine this.
> When the user answers Yes, the workbench invokes doSave() at which point
> the object can be saved. But when the user answers No, I need to find
> this out so I can reload the object (since it is dirty and the user has
> indicated that he does not want to keep the changes).
> Thanks in advance
Re: Dirty editor [message #284836 is a reply to message #284811] Tue, 03 May 2005 06:11 Go to previous messageGo to next message
> (from disk).
This is exactly my issue. I have something other than the editor using the
same content, and if the user refused the save offer, I need to know that
to reload the resource from disk.
Sridhar
> Bob Foster
>> Thanks in advance
Re: Dirty editor [message #284837 is a reply to message #284836] Tue, 03 May 2005 09:11 Go to previous messageGo to next message
If you can find the editor, you can find the page it's in.
IWorkbenchPage.addPartListener(). Your listener will tell you when the
editor closes.
Bob
>> the same contents, the solution is: when all editors for the object
>> close, stop using the document contents and start using the resource
>> contents (from disk).
> the same content, and if the user refused the save offer, I need to know
> that to reload the resource from disk.
> Sridhar
>> Bob Foster
>>> object, and then decides to close the editor. At closing, he is asked
>>> whether to save the object and if the user chooses No, I need to
>>> determine this. When the user answers Yes, the workbench invokes
>>> doSave() at which point the object can be saved. But when the user
>>> answers No, I need to find this out so I can reload the object (since
>>> it is dirty and the user has indicated that he does not want to keep
>>> the changes).
>>> Thanks in advance
Re: Dirty editor [message #284884 is a reply to message #284837] Wed, 04 May 2005 02:14 Go to previous messageGo to next message
> editor closes.
> Bob
Yes I did find that after digging through the newsgroup. However, I am now
looking for way to request user confirmation for the closing of an editor,
and abort the closure if the user refuses. Would you know how I can do
this?
Sridhar
>> Sridhar
>>> Bob Foster
>>>> the changes).
>>>> Thanks in advance
Re: Dirty editor [message #284885 is a reply to message #284884] Wed, 04 May 2005 02:25 Go to previous message
As far as I know you can't do that. (And it would be pretty strange if
you did.)
Bob
>> editor closes.
>> Bob
> now looking for way to request user confirmation for the closing of an
> editor, and abort the closure if the user refuses. Would you know how I
> can do this?
> Regards
> Sridhar
>>> using the same content, and if the user refused the save offer, I
>>> need to know that to reload the resource from disk.
>>> Sridhar
>>>> Bob Foster
>>>>> a view is opened for editing. The user makes some changes to the
>>>>> asked whether to save the object and if the user chooses No, I need
>>>>> to determine this. When the user answers Yes, the workbench invokes
>>>>> (since it is dirty and the user has indicated that he does not want
>>>>> Thanks in advance
Previous Topic:A Question for Editor or JavaEditor plugin Expert....
Next Topic:splitting editor area programmatically
Current Time: Sat Sep 13 10:58:39 EDT 2025
Powered by FUDForum. Page generated in 0.05993 seconds
