Home » Eclipse Projects » GEF » [contribution] Hello Gef #2, a minimalist code example with moveable connected nodes
[contribution] Hello Gef #2, a minimalist code example with moveable connected nodes [message #28317] |
Thu, 10 October 2002 10:20  |
I have written the second episode of my "Hell Gef #" series : save as
before, but it now has connections!
To save space in this newsgroup and to avoid MIME / attachement problems, I
posted the code at Eclipse Wiki's site, in GEF / Examples section.
Direct link (don't know if it is persistent) is
http://eclipsewiki.swiki.net/50, if it does not work, go to
http://eclipsewiki.swiki.net/50.
What will be next? well, I hesitate between these ones:
1 - multi anchors per nodes example
2 - add bendpoints support to the connections
3 - add support to move the end point of a connection from one node to
another
4 - node / connection deletion support
5 - add a palette to allow creation of nodes & connections
of course, this is by order of my current preference, and what I suspect is
the most progressive learning path.
If better idea, please post
Alex.
Re: [contribution] Hello Gef #2, a minimalist code example with moveable connected nodes [message #30440 is a reply to message #28317] |
Sun, 13 October 2002 16:38   |
Originally posted by: sy_cheung2.yahoo.com
Can you add example of using Polygon and PolygonLine?
Thanks.
"Alexandre Vermeerbergen" <ave@ds-fr.com> wrote in message
news:ao40u5$12n$1@rogue.oti.com...
> Hello,
I
> another
is
> Alex.
Current Time: Wed Sep 17 17:22:45 EDT 2025
Powered by FUDForum. Page generated in 0.04757 seconds
