update form eclipse 3.0.1 to 3.0.2 [message #283540] |
Tue, 05 April 2005 13:01 |
Originally posted by: andreas_bauer.arcor.de
Hello!
I have done the update eclipse 3.0.1 to 3.0.2.
But under perfernces/java/compialance and classfiles/compiler compliance
level/,it is only possible to choice JAVA 1.4. I think after updating,
eclipse works with Compiler 1.5 and I have the whole new features of 1.5.
JVM 1.5 is installed. And JDK 1.5 is installed, before Java 2 SDK Standard
Edition 1.4.2_6.
Best regards
Andreas
Re: update form eclipse 3.0.1 to 3.0.2 [message #283553 is a reply to message #283540] |
Tue, 05 April 2005 15:57 |
Originally posted by: manahan.NOSPAM.ca.ibm.com
Andreas wrote:
> Hello!
> 1.5. JVM 1.5 is installed. And JDK 1.5 is installed, before Java 2 SDK
> Standard Edition 1.4.2_6.
> Best regards
> Andreas
JDK 1.5 support is in Eclipse 3.1 not the 3.0 versions.
Peter
Re: update form eclipse 3.0.1 to 3.0.2 [message #283572 is a reply to message #283566] |
Wed, 06 April 2005 00:56 |
John Austin wrote:
> Andreas wrote:
>> Is it eclipse Milestone Build: 3.1M6?
>> A solide eclipse version?
>> Best regards
>> Andreas
> I am using Java 1.5.0 and successfully upgraded Eclipse
> from 3.0.1 to 3.0.2 using the Eclipse software update.
Andreas seems to be able to want to use the new features of JDK 1.5.
Which as far as I know aren't available in Eclipse 3.0.2 JDT.
Peter
Re: update form eclipse 3.0.1 to 3.0.2 [message #283580 is a reply to message #283572] |
Wed, 06 April 2005 12:21 |
Are the new features in eclipse 3.1M6? Is 3.1M6, an installable,
unrestricted eclipse version?
By the way, the box window/perferences/java/compialance and
classfiles/compiler compliance level/ has also to display 1.5, not only
1.4, 1.3?
Best regards
Andreas
Re: update form eclipse 3.0.1 to 3.0.2 [message #283652 is a reply to message #283566] |
Thu, 07 April 2005 23:46 |
my Visual Editor doesn't work for me after updating.
Do function your VE?
Error messages:
Error runing operations
Setup Java Visual Editor(an internal error occured during "Setup Visual
Editor"
An internal error occurred during: "Setup Java Visual Editor".
java.lang.NoClassDefFoundError: org/eclipse/jem/internal/temp/VETimerTests
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1510)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Best regards
Andreas
FUDForum. Page generated in 0.04749 seconds
