Re: Matching source bundle for 3.4.2 draw2d? [message #2410 is a reply to message #2380] |
Thu, 28 May 2009 12:19 |
On 2009-05-28 00:40:11 +0200, pdxjjb@gmail.com (Jeff Berkowitz) said:
> I have org.eclipse.draw2d_3.4.2.v20090114-1330.jar in my 3.4.2 debug
> target environment, but I cannot find a
> org.eclipse.draw2d.source_3.4.2.v20090114-1330.jar to go with it.
> Should I use
> org.eclipse.draw2d.source_3.4.2.v20090218-1145-3317w311_1225 02441.jar ?
> Will the debugger still find the source? Tia...
Do you have installed the SDK or only the GEF package. The sources (and
the documentation) are only found in the SDK. Di you have different
versions of GEF and GEF SDK installed?
Jens
P.S.: As this is a GEF related question, you probably get better
answers in the GEF newsgroup.
Re: Matching source bundle for 3.4.2 draw2d? [message #561278 is a reply to message #2380] |
> Should I use
Jens
FUDForum. Page generated in 0.04055 seconds
