Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » compilation unit vs. working copy
compilation unit vs. working copy [message #27793] Mon, 07 July 2008 19:25 Go to next message
Since apparently we are unable to affect the internal DLTK model of our
source modules, we attempt to build and refine our own models. Somehow we
want the ability to distinguish between clean compilation units (not open as
editor input) and potentially dirty working copies (open in an editor
window). The model of a working copy could refer to something defined in a
model of a compilation unit, but not vice-versa. Thus, we believe we need a
way to distinguish between those two sources of input.
I've seen that the interface ISourceModule has the method isWorkingCopy.
Unfortunately, the parser interface methods that we can easily override do
not refer to that interface:
1) ISourceElementParser.parseSourceModule: (this is the high level interface
when I also do semantic checks per module)
public void parseSourceModule(char[] contents, ISourceModuleInfo astCache,
char[] filename) {
2) ISourceParser.parse: (this is the low level interface where I simply
create the AST tree and populate our corresponding model of declarations)
ModuleDeclaration parse(char[] fileName, char[] source, IProblemReporter
reporter);
The only other thing I see is that both methods have access to the current
IProblemReporter.
From another topic I was told that until you edit a module, IProblemReporter
will be null.
Is that currenly the only way to distinguish between a compilation unit and
a working copy - or is there another way?
Chuck
Re: compilation unit vs. working copy [message #32822 is a reply to message #27793] Mon, 06 October 2008 12:09 Go to previous messageGo to next message
I'd still like to know how to distinguish between clean compilation units
(parsed and/or checked as part of a build) and potentially dirty working
copies (invoked from an editor).
Chuck
"Chuck Doucette" <cdoucette@vaultus.com> wrote in message
news:g4u8ni$803$1@build.eclipse.org...
> as editor input) and potentially dirty working copies (open in an editor
> a way to distinguish between those two sources of input.
> interface when I also do semantic checks per module)
> char[] filename) {
> reporter);
> IProblemReporter.
> IProblemReporter will be null.
> and a working copy - or is there another way?
> Chuck
Re: compilation unit vs. working copy [message #32852 is a reply to message #32822] Mon, 06 October 2008 17:47 Go to previous messageGo to next message
Apparently - my build participants (except for the parser I assume) are now
supposed
to implement IBuildParticipant:
void build(ISourceModule module, ModuleDeclaration ast, IProblemReporter
reporter) throws CoreException;
I'm assuming I can distinguish between clean complition unit and a
potentially dirty working copy by looking at properties of the source
module, i.e. isWorkingCopy()?
Is that true?
Chuck
news:gcddad$ulu$1@build.eclipse.org...
> Chuck
>> a model of a compilation unit, but not vice-versa. Thus, we believe we
>> need a way to distinguish between those two sources of input.
>> do not refer to that interface:
>> astCache, char[] filename) {
>> reporter);
>> current IProblemReporter.
>> Thanks,
>> Chuck
Re: compilation unit vs. working copy [message #33094 is a reply to message #32852] Tue, 07 October 2008 03:19 Go to previous message
isWorkingCopy() is one of the ways, also you can check buildType in the
beginBuild() method of the IBuildParticipantExtension
Alex
> supposed
> Is that true?
> Chuck
>> Thanks,
>> Chuck
>>> reporter);
>>> Thanks,
>>> Chuck
Previous Topic:DLTK (and Eclipse) threads
Next Topic:How to get names of files in a project selected In Script Explorer?
Current Time: Fri Apr 25 18:20:35 EDT 2025
Powered by FUDForum. Page generated in 0.08982 seconds
