List of shortcut keys [message #279463] |
Tue, 18 January 2005 17:59 |
Originally posted by: sfn.chris.sympatico.ca
I am sure that this question has been asked and answered more than once
but I can't find the answer. The question is this I would like to find
a table of atleast the basic shortcut keys for eclipse 3. I have done
some searching and have found only ones of eclipse 2. So if someone
would be so kind as to point me in the directoin of a list. If no list
exists let me know I would be more that happy to create one.
Chris
Re: List of shortcut keys [message #279528 is a reply to message #279526] |
Wed, 19 January 2005 14:08 |
That's great! Thank you very much
Martin Vlk wrote:
> http://eclipse-tools.sourceforge.net/Keyboard_shortcuts_(3.0).pdf
> m.
> Chris Taylor wrote:
>> once but I can't find the answer. The question is this I would like
>> to find a table of atleast the basic shortcut keys for eclipse 3. I
>> have done some searching and have found only ones of eclipse 2. So if
>> someone would be so kind as to point me in the directoin of a list.
>> If no list exists let me know I would be more that happy to create one.
>> Thanks
>> Chris
Re: List of shortcut keys [message #279974 is a reply to message #279967] |
Wed, 26 January 2005 14:47 |
Originally posted by: Chris_Laffra.ca.ibm.com
After using Eclipse long enough your right hand will
instinctively reach upwards and right and blindly find the
combination End+Delete. The annoying thing
is that you have to then still delete the leading spaces
If you badly miss VI, you could google for viplugin,
which allows you to use VI editing mode in Eclipse.
Chris Laffra, http://eclipsefaq.org
"Bucky Pope" <bucky@attglobal.net> wrote in message
news:ct82bq$aot$1@www.eclipse.org...
> Martin Vlk wrote:
> >> Reading over the list, I don't see any function to 'join' lines. Am I
> >> missing something or hasn't that function been implemented?
> >> Regards, bucky pope
> > Do you mean functionality like "J" does in vim? I haven't noticed
> > anything like that in Eclipse, but I might be wrong.
> > m.
> Exactly! That's what I thought. My fingers instinctly do this and
> nothing happens. A smart join would be handy.
> -bucky
Re: List of shortcut keys [message #280008 is a reply to message #279463] |
Wed, 26 January 2005 22:02 |
Originally posted by: john.eclipsefaq.org
Eclipse in the 3.1 stream now has "Key Assist". Press Ctrl+Shift+L to
pop up a window of all key bindings that apply in that particular
context. A handy feature, assuming you can remember the key sequence to
open the key assist dialog :) (or find it in the Help menu).
Chris Taylor wrote:
> once but I can't find the answer. The question is this I would like to
> find a table of atleast the basic shortcut keys for eclipse 3. I have
> someone would be so kind as to point me in the directoin of a list. If
> Thanks
> Chris
FUDForum. Page generated in 0.03881 seconds
