Home » Newcomers » Newcomers » Error while opening eclipse exe
Error while opening eclipse exe [message #27653] Wed, 16 February 2005 16:49 Go to next message
Originally posted by: jayshreekannan.yahoo.com
I am using Eclipse 3 and when i try to open the exe, it gives an error
and when i see the log file, it says
!ENTRY org.eclipse.osgi Feb 16, 2005 16:39:04.307
!MESSAGE Error registering XML parser services.
!STACK 0
java.lang.ClassNotFoundException: javax.xml.parsers.SAXParserFactory
It was working fine, but today i installed Oracle Client in my machine and
after that my eclipse crashed.
Could it be due to some path settings?
Need help.
Thanks in Advance
Re: Error while opening eclipse exe [message #27655 is a reply to message #27653] Wed, 16 February 2005 16:56 Go to previous messageGo to next message
You need to run Eclipse using at least a JRE/JDK 1.4.* See the download page
for more details
String Eclipse using the -vm option to specify the location of such an
install.
HTH
Darins
"J" <jayshreekannan@yahoo.com> wrote in message
news:cv0f4i$fg5$1@www.eclipse.org...
> !STACK 0
> Need help.
> Thanks in Advance
Re: Error while opening eclipse exe [message #27658 is a reply to message #27655] Wed, 16 February 2005 18:14 Go to previous message
Originally posted by: Chris_Laffra.ca.ibm.com
See: http://www.eclipsefaq.org/chris/faq/html/faq25.html
Chris Laffra, http://eclipsefaq.org
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:cv0fk7$hk7$1@www.eclipse.org...
page
> for more details
> install.
> HTH
> Darins
> > Hi,
error
> > !STACK 0
and
> > Need help.
> > Thanks in Advance
Previous Topic:Eclipse and Terminal Services/Citrix
Next Topic:Eclipse fails to launch
Current Time: Tue Apr 29 02:22:15 EDT 2025
Powered by FUDForum. Page generated in 0.14493 seconds
