Error starting 3.1M2 - HELP! [message #277720] |
Wed, 15 December 2004 22:33 |
Originally posted by: mbsingh.optonline.net
I on startup of Eclipse 3.1M2, i recieve and error message stating "An
error has occurred. See the log file xxxx"
the log file entry follows, any ideas on what is causing this? One thing i
noticed in the stack trace is a reference to "org.eclipse.update". under
/org/eclipse/update, all i see is a history folder..could this be causing
the issue? and if so, where do i get the rest of the classes/files that
should be found there? thanks
!SESSION Dec 10, 2004 15:12:34.954
eclipse.buildId=I200409240800
java.version=1.4.2_06
Command-line arguments: -cp
Z:\DevTools\eclipse\startup.jar.org.eclipse.core.launcher.Ma in -Xmx512m
!ENTRY
initial@reference :file:z:/DevTools/eclipse/plugins/org.eclipse.core.runtime_3 .1.0/
0 0 Dec 10, 2004 15:12:34.954
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.core.internal.runtime.PlatformActivator for bundle
org.eclipse.core.runtime is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:158)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:933)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:421)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:366)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:999)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:577)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:488)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:273)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:444)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:186)
org.eclipse.osgi.framework.eventmgr.EventThread.run(EventThr ead.java:104)
Caused by: java.lang.NoClassDefFoundError:
org/osgi/service/prefs/BackingStoreException
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:153)
... 10 more
Root exception:
!ENTRY
initial@reference :file:z:/DevTools/eclipse/plugins/org.eclipse.update.configu rator_3.0.0/
0 0 Dec 10, 2004 15:12:35.94
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start() of
bundle org.eclipse.update.configurator.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:975)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
Caused by: java.lang.Exception: Cannot initialize the Update Configurator
org.eclipse.update.internal.configurator.ConfigurationActiva tor.initialize(ConfigurationActivator.java:93)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start(ConfigurationActivator.java:71)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
... 10 more
Root exception:
!ENTRY org.eclipse.osgi Dec 10, 2004 15:12:35.185
!MESSAGE Startup error
!STACK 1
java.lang.IllegalStateException: Bundle
[91] is not active.
org.eclipse.core.runtime.adaptor.EclipseStarter.ensureBundle sActive(EclipseStarter.java:303)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:227)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
FUDForum. Page generated in 0.02988 seconds
