Home » Eclipse Projects » Eclipse Platform » How to have the program work alone on windows without platform
How to have the program work alone on windows without platform [message #277394] Fri, 10 December 2004 01:49 Go to next message
Originally posted by: dtxtreme_f117.yahoo.com
I am still new to the game of programming but I have created a program
that I want to run on windows without having to open eclipse or even need
to use eclipse to run it. How would I go about doing that?
Thank you
Anthony Wherry
Re: How to have the program work alone on windows without platform [message #277404 is a reply to message #277394] Fri, 10 December 2004 06:14 Go to previous message
The simplest solution is to launch it directly with java. You can export
your project into a jar, create a manifest that specifies the main
class, and then "java -jar yourproject.jar".
You can have eclipse automatically generate a manifest file specifying
the main class, as it seems (in the jar export dialog).
> need to use eclipse to run it. How would I go about doing that?
> Thank you
> Anthony Wherry
Previous Topic:ObjectContribution submenu
Next Topic:Welcome page in Eclipse 3.0.1
Current Time: Fri Nov 14 22:55:27 EST 2025
Powered by FUDForum. Page generated in 0.24646 seconds
