Re: independently backporting virtual tableviewer to 3.0.1 [message #276670 is a reply to message #276463] |
Fri, 26 November 2004 17:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: kim_horne.ca.ibm.com
Erm... maybe? SWT virtual support went into 3.0 so in theory it should
work. Any bugfixes that the viewer relied on would of course not be
there...
Genady wrote:
> I have a UI component that uses very large table. I would like to use
> the virtual table viewer support, but I'm not ready to switch to 3.1 yet.
> Is it possible to patch 3.0.1 sources with the TableViewer class from
> CVS head and create
> a private org.eclipse.jface plugin?
> I have looked at the differences between the two versions and it seems
> like it should work.
> Is that correct? Do I need any of 3.1 SWT features?
> Thanks in advance,
> Genady
FUDForum. Page generated in 0.03161 seconds
