Home » Eclipse Projects » Eclipse Platform » TableViewer & table cell color
TableViewer & table cell color [message #275212] Thu, 04 November 2004 16:02 Go to next message
Originally posted by: nospam_st.gmx.net
How can I modify the front or background color of a table cell
programatically. LabelProvider is obviously only responsible to provide
the text to be displayed in a table cell. In my case the underlying
table has a column displaying numeric values. I want to get them
displayed in black when they are positive and in red when they are
negative.
Thanks for any ideas in advance!
Seb
Re: TableViewer & table cell color [message #275245 is a reply to message #275212] Fri, 05 November 2004 09:29 Go to previous messageGo to next message
> negative.
It is possible to change the color of whole table row and not individual
cells (is it possible?, I will be glad to hear that). You can implement
the IColorProvider Interface to give color to your table rows.
public class YourViewLabelProvider extends LabelProvider implements
ITableLabelProvider, IColorProvider
public String getColumnText(Object element, int columnIndex)
//Your getColoumnText() implementation
/* (non-Javadoc)
* @see
org.eclipse.jface.viewers.IColorProvider#getForeground(java. lang.Object)
public Color getForeground(Object element)
return null; //return forgroud color
/* (non-Javadoc)
* @see
org.eclipse.jface.viewers.IColorProvider#getBackground(java. lang.Object)
public Color getBackground(Object element)
StockQuote quote = (StockQuote) element;
if ((quote.getVarPercentage() < 0)) {
// Red background if balance negative.
return Display.getCurrent().getSystemColor(SWT.COLOR_RED);
//Return back ground color
return Display.getCurrent().getSystemColor(SWT.COLOR_GREEN);
Raj
> Seb
Re: TableViewer & table cell color [message #275252 is a reply to message #275212] Fri, 05 November 2004 10:23 Go to previous message
In 3.1 M3 there is now an ITableColorProvider and an ITableFontProvider that
can be used to determine cell colors and fonts.
Tod Creasey
Platform UI Team
"Sebastian" <nospam_st@gmx.net> wrote in message
news:cme5dd$57r$1@eclipse.org...
> negative.
> Seb
Previous Topic:Replacing an action in popup menu
Next Topic:Listener for recently modified
Current Time: Thu Nov 20 22:20:21 EST 2025
Powered by FUDForum. Page generated in 0.04724 seconds
