Home » Eclipse Projects » Eclipse Platform » CVS: Connection problems on WinXP SP2
CVS: Connection problems on WinXP SP2 [message #274628] Tue, 26 October 2004 16:25 Go to next message
Has anyone run into CVS connection problems running Windows XP SP2? We have
one machine with SP2 connecting to a CVS server using SSH which cannot
connect after creating a new Repository location. This same server is being
accessed by numerous developers (using Eclipse 3.01 and 3.1) using Windows
XP SP1. So we uninstalled SP2 on the machine in question and were able to
connect.
Re: Connection problems on WinXP SP2 [message #274638 is a reply to message #274628] Wed, 27 October 2004 04:59 Go to previous messageGo to next message
Originally posted by: bob.news.gmx.net
"Paul Wuethrich" <paul.wuethrich@eye-ris.com> schrieb im Newsbeitrag
news:clmbg7$m33$1@eclipse.org...
have
being
Windows
to
> connect.
I don't have Eclipse running on SP2, but did try to completely switch off
the firewall with SP2 installed? Did it make a difference? Normally the
firewall blocks only outgoing connections AFAIK, but it still might
interfere with network comm in ways that prevent SSH from working
correctly. Just an idea.
Kind regards
robert
Re: Connection problems on WinXP SP2 [message #274668 is a reply to message #274638] Wed, 27 October 2004 10:01 Go to previous messageGo to next message
Yes, we disabled the personal firewall but that didn't help either.
"Robert Klemme" <bob.news@gmx.net> wrote in message
news:clnnm7$smb$1@eclipse.org...
> have
> being
> Windows
> to
> > connect.
> Kind regards
> robert
Re: CVS: Connection problems on WinXP SP2 [message #274669 is a reply to message #274628] Wed, 27 October 2004 10:21 Go to previous messageGo to next message
Paul,
Feel free to add a comment to bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=73144 stating the problem
you encountered and add yourself to the CC list. Any CVS issues with SP2
will be tracked there.
Michael
> connect.
Re: Connection problems on WinXP SP2 [message #274768 is a reply to message #274668] Thu, 28 October 2004 08:32 Go to previous message
news:clo9cn$5nb$1@eclipse.org...
Darn!
What about ssh, did you check it standalone, i.e. tried to open a
connection from the command prompt? You can enable tracing to console
with "ssh -vvv" to see what happens.
Kind regards
robert
We
> > have
cannot
is
> > being
> > Windows
able
> > to
> > > connect.
off
the
> > Kind regards
> > robert
Previous Topic:When will the eclipse compiler support Java 1.5?
Next Topic:CVS interation in plugin
Current Time: Mon Mar 31 20:31:14 EDT 2025
Powered by FUDForum. Page generated in 0.03248 seconds
