osgi.jar not found [message #273027] |
Thu, 30 September 2004 09:32 |
Originally posted by: jcdiosdado.bizkeliza.org
My program uses the TableViwer class, and the osgi.jar library is needed,
in eclipse 3.0.0 works fine, but when i run as a stand-alone application
it doesnŽt works.
I have all jars in the same directory than the application, but the
osgi.jar does`n found. The error is:
Exception in thread "main" java.lang.NoClassDefFoundError:
org/osgi/framework/InvalidSyntaxException
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1374)
org.eclipse.jface.viewers.TableViewer.internalRefresh(TableV iewer.java:514)
org.eclipse.jface.viewers.TableViewer.internalRefresh(TableV iewer.java:449)
org.eclipse.jface.viewers.StructuredViewer$7.run(StructuredV iewer.java:924)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:862)
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:922)
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:881)
org.eclipse.jface.viewers.TableViewer.inputChanged(TableView er.java:416)
org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:238)
org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1059)
at Parroquial.TableViewerExample.<init>(TableViewerExample.java:75)
Parroquial.SWTCompositeDetalle.InitTableViewer(SWTCompositeD etalle.java:397)
at Parroquial.SWTCompositeTask.InitTable(SWTCompositeTask.java: 381)
at Parroquial.SWTCompositeTask.<init>(SWTCompositeTask.java:80)
at Parroquial.SWTCompositeTask.showGUI(SWTCompositeTask.java:31 3)
at Parroquial.SWTCompositeTask.main(SWTCompositeTask.java:301)
I tryed to include the osgi.jar in classpath, but only it works if i put
the osgi.jar into the C:\Program Files\Java\j2re1.4.2_03\lib\ext directory.
My manifest file is :
Manifest-Version: 1.0
Main-Class: Parroquial.SWTCompositeTask
Class-Path: swt.jar
jface.jar
osgi.jar
mysql-connector-java-3.0.11-stable-bin.jar
My bat file to run the application is:
set JAVAHOME=D:\j2sdk1.4.2_04
set PATH=%JAVAHOME%\bin;%PATH%
java -jar Parroquial.jar -classpath
;swt.jar;jface.jar;osgi.jar;mysql-connector-java-3.0.11-stab le-bin.jar
Could anyone tell me what is wrong?
FUDForum. Page generated in 0.04078 seconds
