Re: Creating an IFolder directly under workspace [message #272021 is a reply to message #272007] |
Mon, 20 September 2004 15:00 |
Originally posted by: john.eclipsefaq.org
Folders in the workspace must belong to a project. For storing private
metadata for your plugin, I suggest using the location provided by
Plugin.getStateLocation() on your plugin instance. This will give you a
directory in a private location reserved for your plugin. The end user
will not be able to see it. You need to use plain java.io APIs to read
and write to this location.
Joe Hudson wrote:
> Hello, I'm developing a plug-in using Eclipse 3.1 and would like to know
> how to create an IFolder directly in the workspace. I would like to use
> this folder for keeping resources associated with my plug-in.
> I know that I can just get the workspace location and do file management
> with java.io.File but I would like to do it the Eclipse way. Could
> someone please correct the code that I am using below? Thanks in advance.
> IPath path =
> ResourcesPlugin.getWorkspace().getRoot().getFullPath().appen d( ".foo");
> IFolder folder =
> ResourcesPlugin.getWorkspace().getRoot().getFolder(path);
> It seems that I can only use IFolders directly under projects because the
> error I receive is shown below:
> java.lang.IllegalArgumentException: Path must include project and resource
> Thank you very much for your help.
> Joe
FUDForum. Page generated in 0.04517 seconds
