| JVM terminated. Exit code=1 [message #270472] |
Wed, 22 April 2009 21:13  |
I don't know much about eclipse, but it is the program we are using in my
class, and I need to get it to work on my computer, so I can work on the
assignments from home...
So pretty much, I am a noob..
I was trying Eclipse 3.4.2 but that kept crashing upon opening it, and so
did 3.3, then 3.2 I got this message below... I had 3.4.2 working before,
but now, won't even open...
thanks for all the help
C:\Windows\system32\javaw.exe
-Xms40m
-Xmx256m
-jar C:\Users\**** ****\Desktop\eclipse.startup.jar
-os win32
-ws win32
-arch x86
-launcher C:\Users\**** ****\Desktop\eclipse\eclipse.ece
-name Eclipse
-showsplash 600
-exitdata ea4_ec
-vm C:\Windows\system32.javaw.exe
-vmargs
-Xms40m
-Xmx256m
-jar C:\Users\**** ****\Desktop\eclipse\startup.jar
| Re: JVM terminated. Exit code=1 [message #270474 is a reply to message #270472] |
Thu, 23 April 2009 01:21   |
> my class, and I need to get it to work on my computer, so I can work on
> the assignments from home...
> so did 3.3, then 3.2 I got this message below... I had 3.4.2 working
> before, but now, won't even open...
Do you have a JRE/JDK installed?
http://www.eclipse.org/downloads/moreinfo/jre.php
http://www.eclipse.org/downloads/moreinfo/java.php
hth,
Ankur..
| Re: JVM terminated. Exit code=1 [message #270480 is a reply to message #270472] |
Thu, 23 April 2009 11:23   |
It is strongly recommended that you specify the full path to your java
executable using eclipse.ini. See here: http://wiki.eclipse.org/Eclipse.ini
Hope this helps,
Eric
> -Xms40m
> -Xmx256m
> -os win32
> -ws win32
> -arch x86
> -name Eclipse
> -showsplash 600
> -exitdata ea4_ec
> -vmargs
> -Xms40m
> -Xmx256m
FUDForum. Page generated in 0.18635 seconds
