Home » Eclipse Projects » Eclipse Platform » Problems with sharing workspace on a team
Problems with sharing workspace on a team [message #270353] Tue, 07 September 2004 02:15
Originally posted by: yilin.microshit.com
I've recently started using Eclipse for my Java development team. We
are using CVS to share the project (including the .project and
..classpath file) between our workspaces. There are a few things we
wish to achieve for workspace settings:
1. All java build paths should be relative to the project or workspace
directory, and should be the same for all developers.
2. All settings in Java->Code Style need to be the same.
3. All settings in Team->File Content and Team->Ignored Resources need
to be the same.
4. The Javadoc Location should be relative to the project or workspace
We've managed to achieve only the first item, by defining a classpath
variable PROJECT_HOME on each of our workstations, and defining the
build paths relative to that. I'm wondering, however, if there's
already a project_home or workspace_home path variable available
somewhere in Eclipse that we can use instead?
TIA,
Eric
Previous Topic:AGAIN: Non file based Editor
Next Topic:Problem with build-in IE viewer in eclipse
Current Time: Sun Oct 26 00:20:02 EDT 2025
Powered by FUDForum. Page generated in 0.02915 seconds
