ArrayIndexOutOfBoundsException in BuilderPropertyPage?? [message #270069] |
Fri, 03 September 2004 17:49 |
Originally posted by: csetera.spss.com
I have a user with some trouble using my 3rd party plugins and the
properties that are added to the projects. He is seeing the attached
stack trace. Can anyone offer any ideas on what might cause this? I
had a look at the code for this page and it seems that as long as the
user has at least one builder defined in their .project file that this
page should not fail in this way. The user appears to have two
builders, so I don't think that is the problem. The full Sourceforge
bug report can be found here
http://sourceforge.net/tracker/index.php?func=detail&aid =1021750&group_id=86829&atid=581073
Thanks for any insights.
Craig
!ENTRY org.eclipse.ui 4 0 Sep 01, 2004 19:48:15.365
!MESSAGE 0
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: 0
org.eclipse.ui.externaltools.internal.ui.BuilderPropertyPage .hand
leEditButtonPressed(BuilderPropertyPage.java:626)
org.eclipse.ui.externaltools.internal.ui.BuilderPropertyPage .acce
ss$4(BuilderPropertyPage.java:625)
org.eclipse.ui.externaltools.internal.ui.BuilderPropertyPage $5.ha
ndleEvent(BuilderPropertyPage.java:317)
at org.eclipse.swt.widgets.EventTable.sendEvent
(EventTable.java:82)
at org.eclipse.swt.widgets.Widget.sendEvent
(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents
(Display.java:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch
(Display.java:2431)
at org.eclipse.jface.window.Window.runEventLoop
(Window.java:668)
at org.eclipse.jface.window.Window.open
(Window.java:648)
at org.eclipse.ui.dialogs.PropertyDialogAction.run
(PropertyDialogAction.java:177)
FUDForum. Page generated in 0.03911 seconds
