Adding dependant jars to Eclipse plugin? [message #269945] |
Fri, 03 September 2004 10:54 |
Originally posted by: mharp.seapine.com
Hey all,
I have a plugin that relies on the Apache Axis project, but can't seem to
figure out how to tell Eclipse to load those libraries when it loads my
plug-in. I keep getting ClassDefNotFound errors and my plugin loading fails.
I have the Axis jars in my PATH, I also added that to the lib dir of my
plugin and made the necessary <runtime> changes but they still aren't found.
<library name="lib\axis.jar">
<export name="*"/>
</library>
Can anyone explain how this is done? I'm gettin real frustrated; it seems
like adding the library elements to runtime should have worked. Second, is
there an Eclipse plug-in version of Axis somewhere out there? I can't seem
to find one, but it would be nice if I could just install Axis to Eclipse
w/o having to include it in my own plugin.
Thanks for any help you can give...
-matt
Re: Adding dependant jars to Eclipse plugin? [message #269978 is a reply to message #269945] |
Fri, 03 September 2004 11:09 |
Daniel Krügler Messages: 853 Registered: July 2009 |
Hello Harpstein,
Harpstein schrieb:
> Hey all,
> <export name="*"/>
> </library>
Yes that behaviour is quite astonishing on first changes from pure Java
programming to plugin programming!
The point is, that you should define a single library plugin, which
actually **contains** the corresponding axis jars and does export them,
like:
<?eclipse version="3.0"?>
<plugin
id="com.example.axis"
name="Your plugin name"
version="1.0.0"
provider-name="Your provider id">
<runtime>
<library name="axis.jar">
<export name="*"/>
</library>
<library name="commons-discovery.jar">
<export name="*"/>
</library>
<library name="commons-logging.jar">
<export name="*"/>
</library>
</runtime>
</plugin>
Now your other plugins, which depend on the axis jar's simplply declare
their dependency on the above defined plugin (com.example.axis).
HTH
Daniel Krügler
FUDForum. Page generated in 0.03468 seconds
