Home » Eclipse Projects » Eclipse Platform » Source code folding in my own editor
Source code folding in my own editor [message #268188] Mon, 23 August 2004 07:45 Go to next message
Originally posted by: mvsteenbergen.eljakim.scratch-this.nl
I'm building my own TextEditor (an Eclipse 3.0 plugin) for editing a
self-defined language. I'd like to add support for folding my source
code, just like in the Java text editor since Eclipse 3.0. Is there a
standard way to do this? An extension, or something in the
SourceViewerConfiguration perhaps?
Thank you in advance,
Martijn van Steenbergen.
Re: Source code folding in my own editor [message #268194 is a reply to message #268188] Mon, 23 August 2004 08:43 Go to previous messageGo to next message
Here's how to configure it:
- in your editor override createSourceViewer(...) by returning a
ProjectionViewer instance
- in your editor extend createPartControl(...) to configure the
projection support
- in your editor extend getAdapter(...) to provide access to the
projection support
- ensure that whenever folding is affected you create/delete/update the
projection annotations
As an example on how to implement above stuff take a look at JavaEditor
and DefaultJavaFoldingStructureProvider. The Java editor the projection
annotations are updated whenever the Java model for the given
compilation unit changes.
HTH
Dani
Re: Source code folding in my own editor [message #268198 is a reply to message #268194] Mon, 23 August 2004 08:56 Go to previous message
Thank you very much! This will keep me busy for quite a while. Slowly
getting there. ^_^
Thanks again,
Martijn.
> projection support
> projection support
> HTH
> Dani
Previous Topic:store a file in the plugin
Next Topic:CVS Question
Current Time: Sun Oct 26 01:37:13 EDT 2025
Powered by FUDForum. Page generated in 0.36460 seconds
