Home » Newcomers » Newcomers » HELP: eclipse crashing
HELP: eclipse crashing [message #268059] Mon, 26 January 2009 09:39 Go to next message
I have used eclipse in the past and i used to love eclipse... but this
time i just can't work with eclispe ... I am usinq xquery through xqdt
plugin and eclipse is crashing every 2 minutes ... which means i have to
restart eclipse, clean up my workspace and create the project again ...
productivity is near zero .. i have read threads which reported the
problem, but nothin is helping ... i am running ganymede on windows
any help/ suggestions would be highly appreciated !
arko
Re: eclipse crashing [message #268073 is a reply to message #268059] Mon, 26 January 2009 11:58 Go to previous messageGo to next message
"arko " <arkadeb@gmail.com> wrote in message
news:466d47929f1712ba16a760f853e0606c$1@www.eclipse.org...
I'm sure that's frustrating!
I can't imagine how you think anyone else would help you, though, with the
level of detail you provided. How about perhaps reading
http://catb.org/~esr/faqs/smart-questions.html, and then letting us know
things like what third-party plug-ins you are using, what the symptoms of
the crash are, what you were doing when it started happening, whether there
are any errors in the error log, whether it happens in a freshly created
workspace, and so forth.
Re: eclipse crashing [message #268078 is a reply to message #268073] Mon, 26 January 2009 12:23 Go to previous message
Originally posted by: nickboldt.gmail.com
You may also enjoy one of these FAQ entries:
http://wiki.eclipse.org/IRC_FAQ#How_do_I_start_Eclipse.3F
http://wiki.eclipse.org/IRC_FAQ#How_do_I_debug_Eclipse.3F_Ho w_can_I_see_what_plugins_are_being_started.3F_How_do_I_start _the_OSGi_console.3F
http://wiki.eclipse.org/IRC_FAQ#I.27m_having_memory.2C_heap. 2C_or_permgen_problems.2C_what_can_I_do.3F
http://wiki.eclipse.org/IRC_FAQ#Crashers.2C_Freezing.2C_and_ other_Major_Issues
As to having to recreate you project over and over, I'd suggest:
a) launch eclipse
b) create your project
c) shut down eclipse
d) back up the project folder (copy it somewhere else, outside your
workspace)
e) restart eclipse
That way you at least have something you can recover from should it
crash again. Why keep starting from scratch?
In addition to Walter's suggestions, it would be useful to know what
version of Java you're using. In Eclipse, Help > About > Config will
tell you this.
Also, if you're running a 64-bit OS (you only said "Windows" but not
what version), please make sure you are using a 64-bit JDK + 64-bit
Eclipse, or else 32-bit JDK + 32-bit Eclipse.
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Previous Topic:How to let Eclipse deploy 1 (!) *.war file instead of expanded war directory tree?
Next Topic:Why isn't syntax correction kicking in?
Current Time: Sat Mar 15 01:31:24 EDT 2025
Powered by FUDForum. Page generated in 0.09832 seconds
