ClassNotFoundException when opening an editor that extends the GenModel editor [message #266999] |
Sun, 15 August 2004 15:38 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mariana.lasprilla.tuhh.de
I have written a plug-in with an editor that extends the EMF .genmodel
Editor (org.eclipse.emf.codegen.ecore.genmodel.presentation.GenMode lEditor
class). The plug-in worked fine under Eclipse 2.1.2 and EMF 1.1, but after
migrating it to Eclipse 3.0 (Release ID: 200406251208), when trying to
load it I get a ClassNotFoundException.
This occurs both when I try to migrate my plug-in manually and when using
the PDE Tool Migrate to 3.0. I've checked the plugin.xml file, the class
names, dependencies, etc. to no avail.
Anybody knows what may be happening here?
Below the plugin.xml and the .log
Thanks in advance,
Mariana
<?eclipse version="3.0"?>
<plugin
id="de.tuhh.sts.mlasprilla.myemf1.0"
name="My EMF 1.0 Plug-in"
version="1.0.0"
provider-name=""
class="de.tuhh.sts.mlasprilla.myemf10.MyEmfPlugin$Implementation ">
<runtime>
<library name="myemf10.jar">
<export name="*"/>
</library>
</runtime>
<requires>
<import plugin="org.eclipse.core.runtime.compatibility"/>
<import plugin="org.eclipse.ui.ide"/>
<import plugin="org.eclipse.ui.views"/>
<import plugin="org.eclipse.jface.text"/>
<import plugin="org.eclipse.ui.workbench.texteditor"/>
<import plugin="org.eclipse.ui.editors"/>
<import plugin="org.eclipse.emf" export="true"/>
<import plugin="org.eclipse.emf.ecore.xmi" export="true"/>
<import plugin="org.eclipse.core.boot"/>
<import plugin="org.eclipse.core.resources"/>
<import plugin="org.eclipse.core.runtime"/>
<import plugin="org.eclipse.jface"/>
<import plugin="org.eclipse.ui"/>
<import plugin="org.eclipse.emf.ecore" export="true"/>
<import plugin="org.eclipse.emf.codegen"/>
<import plugin="org.eclipse.emf.codegen.ecore"/>
<import plugin="org.eclipse.emf.edit.ui"/>
<import plugin="org.eclipse.emf.codegen.ui" export="true"/>
<import plugin="org.eclipse.emf.codegen.ecore.ui" export="true"/>
<import plugin="org.eclipse.jdt.core" export="true"/>
<import plugin="org.eclipse.jdt"/>
</requires>
<extension
point="org.eclipse.ui.editors">
name="My EMF 1.0 Editor"
extensions="genmodel"
icon="icons/sample.gif"
contributorClass="de.tuhh.sts.mlasprilla.myemf10.StateGenActionBarContributor "
class="de.tuhh.sts.mlasprilla.myemf10.editors.MyEmfEditor"
id="de.tuhh.sts.mlasprilla.myemf10.editors.MyEmfEditorID">
</editor>
</extension>
</plugin>
!MESSAGE Plug-in de.tuhh.sts.mlasprilla.myemf1.0 was unable to load class
de.tuhh.sts.mlasprilla.myemf10.editors.MyEmfEditor.
!STACK 0
java.lang.ClassNotFoundException:
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:404)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:307)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:336)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1313)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:131)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:124)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:113)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:196)
Re: ClassNotFoundException when opening an editor that extends the GenModel editor [message #267270 is a reply to message #266999] |
Tue, 17 August 2004 08:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Thanks in advance,
> Mariana
> <plugin
> version="1.0.0"
> provider-name=""
> <runtime>
> <export name="*"/>
> </library>
> </runtime>
> <requires>
> </requires>
> <extension
> </editor>
> </extension>
> </plugin>
> !STACK 0
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
Re: ClassNotFoundException when opening an editor that extends the GenModel editor [message #267273 is a reply to message #266999] |
Tue, 17 August 2004 08:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Problem solved!
My plug-in started working as soon as I erased the
"org.eclipse.core.runtime.compatibility" plug-in from the dependencies.
From reading the migration guide and similar it is not clear to me why
this would happen, though.
> Thanks in advance,
> Mariana
> <plugin
> version="1.0.0"
> provider-name=""
> <runtime>
> <export name="*"/>
> </library>
> </runtime>
> <requires>
> </requires>
> <extension
> </editor>
> </extension>
> </plugin>
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.03528 seconds
