Re: Where does Eclipse store Project information? [message #267005 is a reply to message #266994] |
Wed, 10 December 2008 14:12 |
On 12/10/2008 1:38 AM, Remy Chi Jian Suen wrote:
> Piyush Soni wrote:
>> When I close Eclipse and restart it, the 'Run configurations' for a
>> project are restored. So I it must store the Program Arguments and VM
>> Arguments *for that project* somewhere. But I could not find any such
>> file in my project folder which stores the arguments I have given.
>> Where are they actually stored then?
> See the workspace\.metadata\.plugins\org.eclipse.debug.core\.launche s
> folder.
> > And if it is not in the project folder,
>> is there any specific reason for not keeping it there?
> I guess this may be because people have different settings for launching
> stuff. Just because I have N gigs of RAM to spare for VM arguments when
> running a Java application doesn't mean my coworker also has N gigs to
> spare.
> You can export your launch configuration as a file though.
> http://wiki.eclipse.org/IRC_FAQ#How_do_I_export_a_launch_con figuration.3F
Also, on the Common tab of the Run Configurations or Debug
Configurations dialog, you can select to save it as a "shared" file and
select a location in the project to store it. This allows you to check
in the launch configs with your code into CVS or other version
management system.
Hope this helps,
Eric
FUDForum. Page generated in 0.08093 seconds
