Debugger not working on JRuby (Ganymede) [message #26416] |
Sat, 21 June 2008 22:47  |
Debugging on JRuby has not been working for a long time. I was hoping to
see it come alive as Ganymede release approached. I'm using:
Eclipse: 3.4RC5
DLTK: 0.95.9.v20080611-1900
JRuby: 1.1.2
Java: JDK1.6.0_06
and Debug->Engines = "Ruby Built-In Debugger"
However, the same problem as reported in this note
( http://dev.eclipse.org/newslists/news.eclipse.technology.dlt k/msg00263.html)
still exists. i.e. "Debugging Engine not connected to IDE".
Debugger works fine using classical ruby.
I looked in .metadata, but there was no "{workspace
root}/.metadata/.plugins/org.eclipse.dltk.ruby.basicdebugger /debug_log.txt "
log file to be found, and no directory of this name either.
However, file "{workspace root}/.metadata/.log" did produce the following:
!SESSION 2008-06-21 19:25:46.096
eclipse.buildId=unknown
java.version=1.6.0_06
Framework arguments: -application org.eclipse.ui.ide.workbench
Command-line arguments: -application org.eclipse.ui.ide.workbench -data
C:\testlens\proto9\workspace_9a/../runtime-dltk -dev
file:C:/testlens/proto9/workspace_9a/.metadata/.plugins/org. eclipse.pde.core/DLTK/dev.properties
-os win32 -ws win32 -arch x86
!ENTRY org.eclipse.dltk.launching 4 100 2008-06-21 19:28:37.793
!MESSAGE Debugging Engine not connected to IDE
Any help greatly appreciated!
Steve
Re: Debugger not working on JRuby (Ganymede) [message #26484 is a reply to message #26416] |
Mon, 23 June 2008 05:08   |
Hi Steve,
There are some incompatible changes in the JRuby 1.1.x preventing the
DLTK ruby built-in debugger to operate.
We filed the following bugs in the Eclipse and Codehaus bugtrackers:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=238078
http://jira.codehaus.org/browse/JRUBY-2693
Thanks for reporting this.
Alex
Steve Punte wrote:
> to see it come alive as Ganymede release approached. I'm using:
> Eclipse: 3.4RC5
> JRuby: 1.1.2
> Java: JDK1.6.0_06
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Steve
Re: Debugger not working on JRuby (Ganymede) [message #26515 is a reply to message #26484] |
Mon, 23 June 2008 07:41  |
Hi all,
Also JRuby 1.0.x could not receive "-X" command line option. But we passed it argument.
We updated our code to not pass this argument anymore. (https://bugs.eclipse.org/bugs/show_bug.cgi?id=238093)
If all will be fine, this fix will be included into Ganymede.
Andrei Sobolev.
> Hi Steve,
> Alex
> Steve Punte wrote:
>> Eclipse: 3.4RC5
>> JRuby: 1.1.2
>> Java: JDK1.6.0_06
>> log file to be found, and no directory of this name either. However,
>> -data C:\testlens\proto9\workspace_9a/../runtime-dltk -dev
>> Steve
FUDForum. Page generated in 0.02697 seconds
