Re: eclipse questions [message #265858 is a reply to message #265855] |
Mon, 27 October 2008 08:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Mike Greenawalt![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=mike%40greenawalt.org) Messages: 10 Registered: July 2009 |
Junior Member |
--------------050509040502080302070300
Jason Carr wrote:
> I have been successfully using Eclipse 3.2, but I have some questions
> 1. Is there a way to increase the output space for text after running a
> program?
I assume you are referring to the console output area in the lower
portion of the workbench window. If so, there is a maximize button in
the upper right of the console view. (See the attached image to see
which it is.) Clicking on that button will enlarge the text area, and
you will see more of your output at once.
> 2. If I upgrade will I be able to keep my workspace content?
Generally, yes. It depends on what Eclipse functionality you are using,
and how much that may have changed between versions. Generally, Eclipse
will upgrade your projects to the new level when you use them. I have
had no problem moving right along with my projects and various releases
of Eclipse.
> 3. Is there an official manual for Eclipse?
The Help files are pretty much the manual. You can imagine the
difficulty of publishing "a" manual for Eclipse. Eclipse is many, many
different tools and every user likely uses a different set from others,
so how can you make "a" manual for Eclipse. Saying that, realize that
there are many, many books written on various topics in and about
Eclipse. Go to your favorite online bookseller, and search for Eclipse
-- you will find many.
-- Mike
Content-Type: image/gif;
name="2008-10-27_211701.gif"
Content-Disposition: inline;
filename="2008-10-27_211701.gif"
R0lGODlhwwCQAPcAAAAAAPDw6Fiw6HCwSDBwuPAAAOjo2ACQOKCwyLCIIHhI QKiomKCwwGBg
YKjI4LiwqGBgUJiYkMAgIHh4aKCgmNCwaJCQiPj44FBQUKCIOJh4EJCIYICQ oOjo4ODg0LCw
oABQILiwiNjYyDiAwMCwcMjo+IiIeIA4UNgQENDw+LCQgODY4BAwWPjggIB4 YFhoiJCw8KCI
gOj4+KiooNDQwMC4qHCAoKg4MKCYaPDw8ICoyOjo6KDIgKhwaLBAQNjY2Pj4 +LiQIMjAqHhY
EGBwmPDQiJCYoPjwyOAICGhoaICYuJCw4GiAqMjIuODo+NDIsGBgWKBAQIBo YODQkOjg0LA4
MKCAcLiwcDCYWLjg8LiYWHCQuJiIUOjw+Iio4JgoKNDAkICAcEhISMAgGKCg kEhooJCIgPjo
uMjAuKi40KhgUFiYyLAwMLiYSJiYiJCgwMjIwICg0PjooPj48HBIQABwMGhw gODIiOjo0JhY
UPjoqNDQyODYyJiowHBoYICw2PjgmKDQ6PgAALCQSKiggJB4cKBgYICAgHCI sMDAqNi4eGiQ
wPD4+JhIQKhQSNjQwJCIePDw+Njo+JCAWIBYUNAgIJi48Fh4qPDgsPAICMCo cKCYkEBwqGhw
kIiYwMjg8KCYiFCAsJioyHBwaMiwiFhYUHCw4KCAGLBYUOAQCKiIGLi4qNDI uKigkGB4oODg
2HiYyMgoIJigaGhoWOgACMDQ6JjQ8HBQcIiAeIjA4IB4cMDY8Pj46JiQcMjA sIiYoODw+LjA
2JiQiKiAeMCYONAYGLCooNDIwJCQgJCQcJhoYLjQ6MC4mPjw0MDAsLBQSGho YODAcKiQUEh4
qPjgiKigmMAoIOAQEKioiPAIALioeLg4MMCweIiQqJigoIhwaMioWGiw4ABg KMC4sLgwMHBw
YNjg8JBYWKB4GOgICJCw6HiIoHDA6GBokPDgkJBoYKBQSGhgWHBwcIBAONi4 aFhYWLCQIKg4
OGB4qNjY6GiAsKhgYKiAGMCgQKiIgPDo4CH5BAgAAAAALAAAAADDAJAAAAj+ AA0IHEiwoMGD
CBMqXMiwocOHECNKnGhgAcWLGDNq3Mixo0GLHkOKHEmypEKQJlOqXMmSIcqW MGPKDPlyps2b
OF3m3MmzZ82eQIOq/Cm0qFGORI8qXQoxKdOnUD9GnUq1oNOqWItezcqV59au YG1+DUu25diy
aE2eTcuWZtu3ZuHKTbl2rt2md/N2rKvXLp6TfQMbxIOHimHDhP8S5Cs4LOHD VDxI9gCZsEDG
jbkWjuyBj+fPfCYjxoM5M9XNkkV4FsH6EY1HrENTplLNtF3DnflQoeFsXI0a 4x6xYvVateRW
im2zRa26iYpY6dJlynRtnzFnvpoU99CKSnLlZJn+4xmWSZD58+az+Ri3ypl2 EWQog0eL+xGV
YehTpUJyDb2PBw+4R8Mmks0XXmQi3CdIAYKgkAcyZpiBzDvWLChIFR98ME4T bojggYFgFeaB
h/gxeE8EEUAYoTBunGNhFQtoiAwNfFS0wI045qjjjjz26OOPQAYp5JBEFmkk kK20QgYZkJz3
xSjQxDMLNND4QeUoClioQBhhmMDKIyBqhqAHqJhHDhnIIGOBG5uQUU01FGyy QB7mFSPnKmjQ
EGZWhvEhQhPpLFiIG2YIEwEFM3wA4AfGVENGMeYVsoAxG+5ZlYiq+WMeCsKo GUE1H7TnCxq9
KXqPefeQQUGANh7p6qv+sMYq66xDVqMkKG6MYd485czixwRdIiMMi52agAsu DBaACwWUWkrV
mJo2mKYFZBizynuqiUBDEzWY8IV5bLj5gLNTjamGefBsYoYb1TzgCw3Gdaat L87EUGcEZHwg
lBDkHiTiI3zsY14UKW4yw7UAzyZvE03YK8gYKM6AEAkUV0zxSvz2WxBuf8Zi Xh5uUPuBM/DO
hhsf224SaAFSuDkxEDDHXAEJD+Fg880443xQxiMJWVIQGvkh9NDQzBJPKeWl Y4YFwrQLARRT
Vik0lY8wvI15lCw5MSMwcw2EIjM7hEMJZJdN9thn7zzRAVjwsJDPIwXBC9AY +RFzzDnsUEr+
f+lAsuYCq0CwQw53wwzNn02QYx4dbW4tyhueKMHIHWDTzNDYTmSuuRPJlFBG MMmoLVEdAwzg
dkI3ol6aQJxwMg0noSyiwzLL2GMPL7bXXTgQeZeSiiB9WxDBwVDEQ+XQU4sw 3NWC0BHBJghd
Ecn01FOvSUO9lLC55oeUMP0hokN0wACkY3GSU6lfFE44ppiSSyBZAKNKM/Q3 c4QqFyFvZdFQ
lBJo38LYBKWgMLjdQYMPxzgG8xgHvYNoIxJpSAMCHhe5SGijIdgoQRc2yMEu dOKDHwyfQVpH
gBGs4Q8OkEUdZCGLAYjjAOdrVfpshJHWvS52OqjFLk5xCjnwkCP+IkJZDX4H QAE6AwqEMyDK
FLg4FCFEGx2MIjMa8gBgVI+DdkAAAxhgBxEWZA3hEAA7bJEFSdQBCwNQoUvQ RxQ4uNGNCmlD
CuZIR2DIgBEaaIEGonEQAPjRjw7BFA1q8L9CGRGJSbzbAY9BgwVuooEGIUQX IjjBNyAgH4zo
QEPQQApiEAMM09ugETRnBC8ShIQmROEAQIAFEIRgjTLEEQ0P8saFyFEGuMwl IxjBixZcgI99
BORDIrNERwgiE99g03UIuDsgHI43HitGPIRBBoQQYntOiIQ8GiCPFcijHvJI iCb68Y9/9AMM
u4zELyTBTg6YciAh2IU858mCVcrilW/+Y2NC4MCQQaQgl7qcQy8vAI6EAAAi QXyNIQZGBjfM
YByCS2TMDicCUJhHAuWgljWdQMnHBaMeh+imPA5RD4Q8wR5PgNkj7OEBRkSC A9pzgjsNwjOD
xBOgLAAoPmOIkBlORBr/BOgdBepLLXQED515zbkE0YiGAi6iBnzEIzZRJz9Q EyGgwCYjvklS
XYATIdxABym4wQ1SoIMbQGDEOta61ncK5KYAzUIud6o6IGGECynYpV53OYcL UIMX0uhIn15j
hU0hg10PeFrUiDYLeD0DXOVgF0LcIIlKRq4LK8AANxuAgRUgJAHUOIIiMHEE QCQAZjYomw3c
aoBW7GKvu8z+wi5bsUa7XgSvsGWEQKlxAUZw4agIaoIzKvGxJY2sZJAZkQiM kQ1B+cENSXGD
OaZL3S7IAwNJwC4GwnmQBBzhCBlowxnkcFogMMFzwWACa73x2tx+ghHeaEqO ODKJvO4yZrwA
xAVgNgmPIIgVTShsgyxgMISF5mQAe6wg7uEGaAgQISiKcAQe8APsijQJYkAI P44whSEMYQqA
4AfM8FGCEbPWCLtIazNLWdseZaS+d+OFHADBi5j1F4jEpAEaPrCyQojrXfHy 07aIK4h3NDhf
EJGHGES6XQ0XARD0oAcgisCPNPRhC5fI8iVY240ue/nLXc7JBjaAg0S4AxB6 oIL+Jjbggja7
wL9U4EPVfGFMQViDDAXGFmto1IM6pckPCxiXSMKKjkIXmhsOqanGBIIpALfi PDdwk7XQQJxt
iQA/zT1HBCwwimYFRdGLNkCOSbVQE1UrVNgZTokuJIw1TYBVnw71xhB0DGc4 QxkWchAZJvUA
fyiOQVUIGTV1USlZKyWhTVjFKnB9Hv5coz+QThGBF4CLPMWSVtjOtra3Task kQEUwjBDGHCh
AAah5zwF+IIfplQOYHlJBAawhLznTe962/ve+M63vvfN7377+98AD3i/YaAO dXghDnHYAiJc
cQsJ0OLhtEDCCV5AhIq7ggmIgAUyABZvgXv84yAPucj+R+5xgi/h4LBQ+MLb 0Y4XuNwVFScC
E/SxBVjEoUMfMjZTEMwKZ6zCGAuIUwTc4AYWSTpAcfACgXKu82Mj+BhoGMcD PrCAN1GgGrxe
hS9Y4YUlxIcKTWcKaoTcBFIpG0DKxo52HrEEdXTnO2E/yslE4JpjMOzuTSAO bPhQcOTE/SmP
kcxq6O4aqcZGMjCAQW3+DhXUCB40spmNvFfH+Jg85jCTMZl38DD5yp9mM4dJ zEA673mswH30
lqB86YVC+tWTpfWuBwvsY8+V2dMeK63ntu53z/veb7v1zQy+8IdP/OIb//jI T77yl8/8mHUA
+R0AfvOnT/3qW//62B/+83P+EIAOeF+TBniF+F8RACC8QvrZT7/618/+6z8/ ADngfgDmP/8d
eP8VQBAB+tvP//773//P1wHxR38BsAP2d3/5t3//t4AM2IDLF4AEOH/fh4A0 oIAOeIEYmIFA
AIEECAcT2AH41wQWqIEkWILsx4Hz90YTGIIjaIIu+ILT93wGQH9v5Ebfx4Kp NxAwuIM8yHzP
R34BoIIqCIJAIII5KBA9mIRKqH3mtwNvdIAqiIMosYRUWIUbaH4d4IQH6H0e SIRGOIVWGIY8
+IMf+IHhV4QtKIZqeIFkWIY3KIU6uIZyqIHP5wFuqEnjh4ZHaABz2IdsCAQB MH6CKIjlV4F7
6If+iLiAHeABxicC0XeIiRiJ7dcBAbAHTUAviZCJmmhrNJADjwiGkhiK2UeJ 9Bd/czAHzfSJ
cSiKrFh9pDh/poiKu6OKSNiKtth8rwh/OXCKqZiGt/iLwZeLsdiLkAiMxkh8 wriLslg4tMiH
x/iMwUiAwziLvgiNwJiMvEiNxWiN3IiNy3g3zciN4riB0qiMxAiK4/iM3niO q5iOx7iO2oiO
7niN5ZiNzFiN8yiJ8HiP25iPt7iP4IiP/oiIAOl8AjmQfViQMBOOCPmP9fiN BtmPDRmKCrmB
BzmRaliRDImRoqiRF8mRVuiREgmSfiiS8kiSJfmQ7FiLKJmIJtmOLZmakCoZ jzAZk3L4kixp
k3OIk86okzs5k/x4kj4Zhjw5lD9ZiuZIkzlplEQJlAE5kky5hEUZlWI4lVQZ kk4ZkUJ5lT1o
lVwplVm5kB/5lRjolWTZlWFpkVB5li5olmwJg275lm2Zlhspl3BJl2NplwCI l2upl2XJl1vp
l3+JlPb4lIEpmA4Yl4jJhoBZk4vJmIQJkWLZl4/5fzwZEAAh/gA7
--------------050509040502080302070300--
FUDForum. Page generated in 0.07596 seconds
