Re: Set main project [message #265796 is a reply to message #265777] |
Fri, 24 October 2008 14:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
On 10/24/2008 4:12 AM, Timm Tross wrote:
> Hello,
> I wonder if you can set a project as the 'main project' in eclipse, to
> let it know, which project to built/debug/run... when listening to a
> hotkey?
There is no notion of a "main" project in Eclipse.
First of all, as long as you don't turn off the Project > Build
Automatically option, all projects are constantly kept built as you
work, so there is no need to explicitly do a build before running or
debugging.
As for easily launching the app, you can set a Preference so that it
always launches the last thing you ran: go to Preferences > Run/Debug >
Launching and you'll find an option named "Always launch the previously
launched application" - turn that on and when you hit F11 (Debug) or
Ctrl+F11 (Run) it will launch the same project that you ran most recently.
Hope this helps,
Eric
FUDForum. Page generated in 0.07502 seconds
