Home » Eclipse Projects » Eclipse Platform » Why NullPointerException?
Why NullPointerException? [message #265597] Thu, 05 August 2004 20:40 Go to next message
Originally posted by: zc.ssc.stn.sh.cn
I want to write to console of runtime workbench, my code is:
MessageConsole console = new MessageConsole("myConsole", null);
ConsolePlugin.getDefault().getConsoleManager().addConsoles(
new IConsole[] {console});
MessageConsoleStream stream=console.newMessageStream();
stream.println("Ok, I can write to the console!");
But error in the .log file:
!MESSAGE java.lang.NullPointerException
at org.eclipse.ui.console.AbstractConsole.<init>(AbstractConsole.java:130)
at org.eclipse.ui.console.MessageConsole.<init>(MessageConsole.java:73)
why?
Re: Why NullPointerException? [message #265679 is a reply to message #265597] Fri, 06 August 2004 03:38 Go to previous messageGo to next message
>why?
Looks like you do not run the code in a run-time workbench.
Dani
>Thanks
Re: Why NullPointerException? [message #265975 is a reply to message #265679] Sun, 08 August 2004 20:34 Go to previous messageGo to next message
But I do run it in runtime workbench!
> >why?
> Dani
> >Thanks
Re: Why NullPointerException? [message #265991 is a reply to message #265975] Sun, 08 August 2004 23:11 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
"zc" <zc@ssc.stn.sh.cn> wrote in message news:cf6grd$82i$1@eclipse.org...
> > > at
> > > at
> > >why?
So, what is on line 130 of AbstracConsole? I mean, what is causing the NPE?
Re: Why NullPointerException? [message #266010 is a reply to message #265991] Mon, 09 August 2004 01:14 Go to previous messageGo to next message
"Chris Laffra" <Chris_Laffra@ca.ibm.com> wrote in message
news:cf6pst$hl9$1@eclipse.org...
> > > > at
> > > > at
> > > >why?
NPE?
Line 130 attempts to access the ConsolePlugin default instance.
zc must be referencing and using the MessageConsole outside of the context
of its plugin and the Console plugin's lifecycle.
That is the plugin's default instance does not exist which results in the
NPE.
Darins
Re: Why NullPointerException? [message #266019 is a reply to message #266010] Mon, 09 August 2004 03:41 Go to previous messageGo to next message
So how can I do? I just want to output some message to the console of
runtime workbench.
> > > > > at
> > > > > at
> > > > >why?
> NPE?
> NPE.
> Darins
Re: Why NullPointerException? [message #266082 is a reply to message #266019] Mon, 09 August 2004 10:28 Go to previous messageGo to next message
"zc" <zc@ssc.stn.sh.cn> wrote in message news:cf79qb$3u2$1@eclipse.org...
> runtime workbench.
Why didn't you say that?
http://eclipsefaq.org, FAQ 307, "How do I write to the console from a
plug-in?"
Re: Why NullPointerException? [message #266156 is a reply to message #266082] Mon, 09 August 2004 21:08 Go to previous messageGo to next message
I copy the code in FAQ 307 in my program, but when I run it in runtime
workbench, NullPointerException error in the line "IConsoleManager conMan
= plugin.getConsoleManager();".
> > runtime workbench.
> plug-in?"
Re: Why NullPointerException? [message #266160 is a reply to message #266010] Mon, 09 August 2004 21:19 Go to previous messageGo to next message
Thank you, I think you are right. So how can I use the console in the
plugin's lifecycle?
> > > > > at
> > > > > at
> > > > >why?
> NPE?
> NPE.
> Darins
Re: Why NullPointerException? [message #266162 is a reply to message #266082] Mon, 09 August 2004 21:21 Go to previous messageGo to next message
I copy the code in FAQ 307 to my program, but when I run it in runtime
workbench, there is NullPointerException error in the line
"IConsoleManager conMan = plugin.getConsoleManager();" :-(
> > runtime workbench.
> plug-in?"
Re: Why NullPointerException? [message #266166 is a reply to message #266160] Mon, 09 August 2004 22:43 Go to previous messageGo to next message
Have your plugin require the Console plugin in the plugin.xml of your
plugin.
Something like:
<requires>
<import plugin="org.eclipse.ui.console"/>
</requires>
I would guess that you have just put the Console plugin JARs on your build
path and are attempting to build and run using that setup. This will not
work.
HTH
Darins
"zc" <zc@ssc.stn.sh.cn> wrote in message news:cf97rl$49c$1@eclipse.org...
> plugin's lifecycle?
> > > > > > at
> > > > > > at
> > > > > >why?
> > NPE?
context
the
> > NPE.
> > Darins
Re: Why NullPointerException? [message #266168 is a reply to message #266166] Mon, 09 August 2004 22:00 Go to previous messageGo to next message
Hit the nail on the head! I add this line in my plugin.xml file and it
works!
Thank you!!!
> plugin.
> Something like:
> <requires>
> </requires>
> work.
> HTH
> Darins
> > plugin's lifecycle?
> > > > > > > at
> > > > > > > at
> > > > > > >why?
> > > NPE?
> context
> the
> > > NPE.
> > > Darins
Re: Why NullPointerException? [message #266250 is a reply to message #266168] Tue, 10 August 2004 10:23 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
For future reference, you don't need to include plugin jars of other
plugins that you need. Just update the plugin.xml file and the PDE will
automatically include any plugin jar from the required plugin that you
need. You almost never have to touch the java build path of a plugin
project because the pde manages to for you.
Thanks, Rich Kulp
Re: Why NullPointerException? [message #266635 is a reply to message #266250] Wed, 11 August 2004 21:07 Go to previous message
Thank you!
Previous Topic:Please help on MultiPageEditorPart
Next Topic:Can not resolve IFileEditorInput
Current Time: Wed Oct 29 22:20:12 EDT 2025
Powered by FUDForum. Page generated in 0.05833 seconds
