No sorting called on TableViewer.update() [message #265546] |
Thu, 05 August 2004 13:46  |
Originally posted by: smallpocks.yahoo.com
I have a problem with my TableViewer. I have given it a sorter that sorts by
the String name of my objects. It works fine when the plugin is first
started up. It sorts everything. However, when the model changes, I call
TableViewer.update(model_object,null) and the table does not get sorted. I
am sure that update is getting called. If I replace update with refresh then
everything works just fine. It's just that I'd rather be able to call update
for efficiency reasons. I am running Eclipse Release 3.0.
Thanks for any help.
Nels
Re: No sorting called on TableViewer.update() [message #265573 is a reply to message #265563] |
Thu, 05 August 2004 16:41   |
Thanks for responding. Although you may be correct, and I am perfectly fine
with calling refresh, I was only doing what I had seen in the Eclipse
JavaDoc.
From org.eclipse.jface.viewers.StructuredViewer:
update
public void update(Object[] elements,
String[] properties)
If the viewer has a sorter which is affected by a change to one of the
properties, the elements' positions are updated to maintain the sort order.
If this is not correct, maybe the JavaDoc should be updated.
Nels
"Paul Keyser" <rolarenfan@earthlink.net> wrote in message
news:ceu0ls$qvj$3@eclipse.org...
> I'm pretty sure that update() is not supposed to call the sorter; in
> fact, the update() suite of methods exists precisely to just update one
> or a few items. In your case, you'd want to use refresh(), I think.
> HTH,
> Paul
> Nels Beckman wrote:
> > Hello,
sorts by
I
then
update
> > Nels
Re: No sorting called on TableViewer.update() [message #266025 is a reply to message #265573] |
Mon, 09 August 2004 04:16  |
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=50956
and if possible, attach steps to reproduce the problem.
Markus
> JavaDoc.
> update
> Nels
FUDForum. Page generated in 0.04170 seconds
