Home » Eclipse Projects » Plugin Development Environment (PDE) » Where is the .api_description file created?
Where is the .api_description file created? [message #26303] Mon, 13 October 2008 10:15 Go to next message
Hy all,
I'm trying to make a build of the org.eclipse.jdt.core plugin (i've
downloaded the entire project from the cvs) but I can't seem to make one
that will actually work. After looking into the differences between the
jar I create and the one that exists in my eclipse release I have
noticed that, besides the missing signatures, the official release of
the plugin contains a file named ".api_description" which I can't seem
to create on my own. I've tried using the export wizard and the ant
scripts found in /scripts but both methods output the same jar.
Any clues? I'm kinda desperate right now 'cause I've been trying for days...
Thanks!
Re: Where is the .api_description file created? [message #26344 is a reply to message #26303] Mon, 13 October 2008 10:59 Go to previous messageGo to next message
Originally posted by: zx.code9.com
Andrei Serea wrote:
> Hy all,
> days...
The .api_description file comes from PDE API Tools. You can learn more
about it here:
https://www.ibm.com/developerworks/opensource/library/os-ecl ipse-api-tools/
~ Chris
Re: Where is the .api_description file created? [message #27146 is a reply to message #26344] Fri, 17 October 2008 07:46 Go to previous message
Thanks, this helped a lot.
But now I am again stuck. I have found the ant task that generates the
api_description file (the AntFileGenerationTask class) but what I don't
understand is where does eclipse api tools run this task and how.
Could someone please help me with this matter...i saw that this is very
poorly documented since i only found one web page on the entire eclipse
site mentioning this file ( http://wiki.eclipse.org/ApiTools_Milestones )
Andrei Serea.
Re: Where is the .api_description file created? [message #582687 is a reply to message #26303] Mon, 13 October 2008 10:59 Go to previous message
Andrei Serea wrote:
> Hy all,
> days...
about it here:
~ Chris
Re: Where is the .api_description file created? [message #582981 is a reply to message #26344] Fri, 17 October 2008 07:46 Go to previous message
Andrei Serea.
Previous Topic:Unable to locate Companion shared library
Next Topic:Contribute Run External Program Actions via Plugin
Current Time: Fri Apr 25 19:08:05 EDT 2025
Powered by FUDForum. Page generated in 0.08683 seconds
