Home » Newcomers » Newcomers » Java class creation
Java class creation [message #265076] |
Tue, 30 September 2008 14:51  |
In the main menu, is there any reason why I shouldn't have the option:
"Window | Open Perspective | Java"
Under "Window | Open Perspective.." all I have is:
CVS Repository Exploring
Team Synchronising
Other...
as you can see there is no "Java" option
and under "Other..." there is nothing that resembles a Java perspective.
This is related to my earlier thread where I was told to go to a section
of the menu where I seem to be missing icons that will enable me to do
anything Java related like create a Java Project/Package/Class.
Any help would be immensely appreciated.
Re: Java class creation [message #265084 is a reply to message #265079] |
Tue, 30 September 2008 15:30   |
Thank you for your response.
Now, I downloaded and installed Eclipse a long time ago so I do not
remember the package name or version, however, the strange thing is - just
a month ago, this was all working perfectly. I don't know what has
happened but since then, anything to do with Java has vanished from
Eclipse. Last month, I was able to create Java projects, Java Packages and
classes without any problems, but now, all the Java tools are no longer
there.
Can you recommend a tool or site or file for me to download on top of my
current eclipse IDE which would reinstall the Java SDK Tools?
I assume if I install the latest and greatest version of Eclipse it will
simply install itself on top of the existing version?
Thanks a lot.
Re: Java class creation [message #265087 is a reply to message #265084] |
Tue, 30 September 2008 15:44   |
--------------070100030503080003030108
Heval,
Grab your favorite package from here and be sure it has JDT in it.
http://www.eclipse.org/downloads
Install it (unzip it) in a new location, not over top of an old one! Be
sure you have a 5.0 JRE installed and that it's the default one that's
used when you run eclipse.exe, i.e., try java.exe -version to be sure.
> just a month ago, this was all working perfectly. I don't know what
> has happened but since then, anything to do with Java has vanished
> from Eclipse. Last month, I was able to create Java projects, Java
> Packages and classes without any problems, but now, all the Java tools
> are no longer there.
> my current eclipse IDE which would reinstall the Java SDK Tools?
> will simply install itself on top of the existing version?
> Thanks a lot.
<html>
<head>
http-equiv="Content-Type">
</head>
Heval,<br>
<br>
Grab your favorite package from here and be sure it has JDT in it. <br>
<blockquote><a href="http://www.eclipse.org/downloads">http://www.eclipse.org/downloads</a><br>
</blockquote>
used when you run eclipse.exe, i.e., try java.exe -version to be sure.<br>
<br>
<br>
Heval wrote:
<blockquote
cite="mid:2a7788c439827e5012dc5b932ed4716f$1@www.eclipse.org"
type="cite">Thank you for your response.
<br>
<br>
just a month ago, this was all working perfectly. I don't know what has
and classes without any problems, but now, all the Java tools are no
longer there.
<br>
<br>
<br>
<br>
<br>
<br>
Thanks a lot.
<br>
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------070100030503080003030108--
Re: Java class creation [message #265094 is a reply to message #265087] |
Tue, 30 September 2008 15:46   |
Ed Merks wrote:
> Heval,
>> Thanks a lot.
I have installed the latest version, and the Java options are there..
Thanks you for your help
Current Time: Tue Jul 01 13:28:00 EDT 2025
Powered by FUDForum. Page generated in 0.08065 seconds
