Using XDC with CCSv3.3 [message #2192] |
Wed, 22 April 2009 08:22 |
sgspecker Messages: 8 Registered: July 2009 |
Junior Member |
I've run into a problem installing the XDC tools for CCSv3.3. It appears
that when you install XDC v2.95, the proper hooks are put in place
allowing CCS to recognize and use XDC. If, on the other hand, you only
install another version of XDC (say XDC 3.10), XDC is not recognized by
CCS.
Looking in the release notes for XDC 3.10, it states that CCSv3.3 is
supported, but there are not any additional installation steps indicated.
Is there a procedure needed to get CCSv3.3 to recognize XDC? If so, can
someone point me to it; if not, can you help me document it.
Scott
Re: Using XDC with CCSv3.3 [message #2220 is a reply to message #2192] |
Wed, 22 April 2009 14:14 |
Dave Russo Messages: 172 Registered: July 2009 |
> CCS.
Since you are installing XDCtools "by hand", you probably need to follow
the procedure described in "Network Installation":
http://rtsc.eclipse.org/docs-tip/XDCtools_Installation_Guide #About_Network_Installations.
Normally the XDCtools installer on Windows automatically makes some
registry modifications required by CCS 3.3. During a "network install"
(that allows a team to share a common XDCtools), each developer must
manually update their registry by following the steps outlined in
http://rtsc.eclipse.org/cdoc-tip/index.html#xdc/tools/config uro/ccs/package.html
> Scott
FUDForum. Page generated in 0.04019 seconds
