Home » Archived » BIRT » RCP hangs while generating report on MacOSX. Works fine on windows.
RCP hangs while generating report on MacOSX. Works fine on windows. [message #263604] Wed, 19 December 2007 19:05
I have integrated BIRT 2.2.0 into my RCP(Eclipse 3.3.0) to generate
reports. My report design uses a scripted data set and in it I am
accessing a Java object. The report generation works fine on Windows but
on MacOSX it doesnt - Although when i launch/debug the RCP through the
rcp's product file on macosx, it works fine. But when i export the rcp
using the product export wizard, and run it, it doesn't work.
I've checked the BIRT logs and it seems it gets stuck while preparing the
script query...
here's the birt log when i run the rcp:
Dec 20, 2007 3:18:26 AM
org.eclipse.birt.data.engine.impl.GroupBindingColumn GroupBindingColumn
FINER: ENTRY null 0
{amount=org.eclipse.birt.data.engine.api.querydefn.Binding@691c75,
description=org.eclipse.birt.data.engine.api.querydefn.Binding@cb69f3,
quantity=org.eclipse.birt.data.engine.api.querydefn.Binding@98f451,
rate=org.eclipse.birt.data.engine.api.querydefn.Binding@d0093a}
FINER: RETURN
Dec 20, 2007 3:18:26 AM org.eclipse.birt.data.engine.impl.PreparedQuery
<init>
FINE: Finished preparing the PreparedQuery.
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery
FINER: RETURN
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery
FINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineImpl@4676
org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@380405
org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@2681bb
{PDF_RENDER_CONTEXT=org.eclipse.birt.report.engine.api.PDFRenderContext@f2d81,
HTML_RENDER_CONTEXT=org.eclipse.birt.report.engine.api.HTMLRenderContext@53df31}
PreparedScriptDSQueryss
FINER: RETURN
FINER: PreparedScriptDSQuery starts up.
Dec 20, 2007 3:18:26 AM org.eclipse.birt.data.engine.impl.DataEngineImpl
prepare
FINE: Finished preparing query.
prepare
FINER: RETURN
And here's the log when i launch the RCP through eclipse:
Dec 20, 2007 3:19:43 AM
FINER: ENTRY null 0
{amount=org.eclipse.birt.data.engine.api.querydefn.Binding@8fff7b,
description=org.eclipse.birt.data.engine.api.querydefn.Binding@ce0e12,
quantity=org.eclipse.birt.data.engine.api.querydefn.Binding@fde308,
rate=org.eclipse.birt.data.engine.api.querydefn.Binding@443ce2}
FINER: RETURN
Dec 20, 2007 3:19:43 AM org.eclipse.birt.data.engine.impl.PreparedQuery
<init>
FINER: RETURN
FINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineImpl@2b212d
org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@75d78a
org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@4de8d3
{PDF_RENDER_CONTEXT=org.eclipse.birt.report.engine.api.PDFRenderContext@f0afc8,
HTML_RENDER_CONTEXT=org.eclipse.birt.report.engine.api.HTMLRenderContext@1c0d6}
FINER: RETURN
Dec 20, 2007 3:19:43 AM org.eclipse.birt.data.engine.impl.DataEngineImpl
prepare
prepare
FINER: RETURN
Dec 20, 2007 3:19:43 AM org.eclipse.birt.data.engine.impl.QueryExecutor
QueryExecutor
FINER: ENTRY [object Object]
org.eclipse.birt.data.engine.impl.aggregation.AggregateTable @d134fc
org.eclipse.birt.data.engine.impl.DataEngineSession@edc5be
QueryExecutor
FINER: RETURN
doPrepare
FINER: Start to prepare the execution.
Dec 20, 2007 3:19:43 AM org.eclipse.birt.data.engine.impl.DataSetRuntime
DataSetRuntime
FINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@4de8d3
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@fd4204
DataSetRuntime
FINER: RETURN
org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime ScriptDataSetRuntime
FINER: RETURN
org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime <init>
FINER: ScriptDataSetRuntime starts up
Dec 20, 2007 3:19:43 AM org.eclipse.birt.data.engine.impl.ParameterUtil
ParameterUtil
FINER: ENTRY null
org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@bb31bc
org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@75d78a [object
Object]
ParameterUtil
FINER: RETURN
doPrepare
FINER: Finish preparing the execution.
org.eclipse.birt.data.engine.impl.ServiceForQueryResults
FINER: ENTRY org.eclipse.birt.data.engine.api.DataEngineContext@5fd428
[object Object] 2
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@de611c
org.eclipse.birt.data.engine.impl.ExprManager@b98d4e
FINER: RETURN
Dec 20, 2007 3:19:43 AM org.eclipse.birt.data.engine.impl.QueryResults
QueryResults
FINER: ENTRY
org.eclipse.birt.data.engine.impl.ServiceForQueryResults@ec00de
QueryResults
FINER: RETURN
Dec 20, 2007 3:19:43 AM org.eclipse.birt.data.engine.impl.ExprManagerUtil
ExprManagerUtil
FINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@b98d4e
ExprManagerUtil
FINER: RETURN
execute
FINER: Start to execute
Dec 20, 2007 3:19:43 AM org.eclipse.birt.data.engine.impl.ExecutorHelper
ExecutorHelper
FINER: ENTRY null
ExecutorHelper
FINER: RETURN
Dec 20, 2007 3:19:43 AM org.eclipse.birt.data.engine.script.ScriptEvalUtil
evaluateJSExpr
FINER: ENTRY evaluateJSExpr() scriptText=function __bm_OPEN() {
totalAmount = 0.0;
iter = jemsProject.getJemsQuotation().getJemsQuotationCosts().itera tor();
} , source=DataSet[jqc].__bm_OPEN, lineNo=1
evaluateJSExpr
FINER: ENTRY evaluateJSExpr() scriptText=__bm_OPEN(),
evaluateJSExpr
FINER: ENTRY evaluateJSExpr() scriptText=function __bm_FETCH() {
if( !iter.hasNext() ){
return false;
st = iter.next();
row["description"] = st.getDescription();
row["quantity"] = st.getQuantity();
row["rate"] = st.getRate();
amount = st.getQuantity() * st.getRate()
row["amount"] = amount;
totalAmount = totalAmount + amount;
return true;
} , source=DataSet[jqc].__bm_FETCH, lineNo=1
evaluateJSExpr
FINER: ENTRY evaluateJSExpr() scriptText=__bm_FETCH(),
Dec 20, 2007 3:19:43 AM org.eclipse.birt.data.engine.script.JSRowObject
JSRowObject
FINER: ENTRY
Dec 20, 2007 3:19:43 AM org.eclipse.birt.data.engine.script.JSRowObject has
FINER: ENTRY description
FINER: RETURN true
Dec 20, 2007 3:19:43 AM org.eclipse.birt.data.engine.script.JSRowObject put
FINER: RETURN
FINER: ENTRY quantity
FINER: RETURN true
FINER: RETURN
FINER: ENTRY rate
FINER: RETURN true
FINER: ENTRY rate
FINER: RETURN
FINER: ENTRY amount
FINER: RETURN true
FINER: ENTRY amount
FINER: RETURN
evaluateJSExpr
return false;
st = iter.next();
return true;
evaluateJSExpr
org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper populateData
FINE: MemoryCache is used
FINE: Time consumed by cache is: 0 second
org.eclipse.birt.data.engine.expression.ColumnReferenceExpre ssion
ColumnReferenceExpression
FINER: ENTRY amount
FINER: RETURN
FINER: RETURN
FINER: RETURN
FINER: ENTRY rate
FINER: RETURN
FINER: ENTRY amount
FINER: RETURN
FINER: RETURN
FINER: RETURN
FINER: ENTRY rate
FINER: RETURN
execute
FINER: Finish executing
Dec 20, 2007 3:19:43 AM org.eclipse.birt.data.engine.impl.ResultIterator
ResultIterator
FINER: ENTRY
org.eclipse.birt.data.engine.impl.QueryResults$ResultService@818168
org.eclipse.birt.data.engine.executor.transform.CachedResult Set @56ebb9
[object Object]
ResultIterator
FINER: RETURN
getResultIterator
FINE: finished
org.eclipse.birt.data.engine.impl.BindingColumnsEvalUtil
FINER: ENTRY
[object Object]
org.eclipse.birt.data.engine.impl.ResultIterator$RDSaveHelper@5e6a56
[org.eclipse.birt.data.engine.impl.GroupBindingColumn@9760e9] {}
FINER: RETURN
getValue
FINER: get of value binding column: description
getValue
FINER: get of value binding column: quantity
getValue
FINER: get of value binding column: rate
getValue
FINER: get of value binding column: amount
close
FINE: a ResultIterator is closed
close
FINER: executor closed
close
FINE: QueryResults is closed
Dec 20, 2007 3:19:44 AM DataEngineImpl shutdown
FINER: ENTRY
Dec 20, 2007 3:19:44 AM org.eclipse.birt.data.engine.impl.DataEngineImpl
shutdown
INFO: Data engine shuts down
shutdown
FINER: RETURN
Previous Topic:Update Site for 2.2.1.1? for Web Tools Integration?
Next Topic:Use Case: 1 Data Source & 20 Reports
Current Time: Tue Jul 01 03:34:41 EDT 2025
Powered by FUDForum. Page generated in 0.06800 seconds
