Home » Archived » BIRT » ScriptedDataSetEventAdapter and DataSet UI
ScriptedDataSetEventAdapter and DataSet UI [message #263008] Mon, 10 December 2007 11:27 Go to next message
I wrote a scripted dataSet event adapter which calls an EJB to populate my
dataset. I would like now, to have a more dynamic adapter that generates
the metadata.
The describe method is called at runtime but not when designing the
dataset.
So, if someone can answer to same of the following questions, maybe I can
succeed ;)
1) Is the adater called by the UI part ?
2) If yes, where is the best place to put my Adapter (perhaps it's a
classpath problem), if no how can i do to describe dynamically the
metadata of my dataset.
3) In the open method of the adapter how can I access to dataset
parameters ?
Thaks a lot for answers,
Thibaud
Re: ScriptedDataSetEventAdapter and DataSet UI [message #263016 is a reply to message #263008] Mon, 10 December 2007 16:20 Go to previous messageGo to next message
1 - Yes
2 - Can be in the same workspace or add it to the viewer plugin web-inf/lib.
3 - There is a bug for this (150192).
Jason
Thibaud wrote:
> Hello,
> my dataset. I would like now, to have a more dynamic adapter that
> generates the metadata.
> dataset.
> can succeed ;)
> parameters ?
> Thibaud
Re: ScriptedDataSetEventAdapter and DataSet UI [message #263068 is a reply to message #263016] Tue, 11 December 2007 07:44 Go to previous message
Thanks a lot for all these answers, it works fine (except for ui part but
i have to check my code ...)
The acces to parameter is a really big limitation when using handler.
There no workaround mentionned but I saw it was plan soon, for 2.3M4.
Thanks again Jason.
Thibaud
Previous Topic:Yellowfin releases version 3.3
Next Topic:Oracle JDBC driver - truncated list of tables
Current Time: Mon Oct 13 20:01:14 EDT 2025
Powered by FUDForum. Page generated in 0.02645 seconds
