Problem using a library with a template [message #262685] |
Wed, 05 December 2007 08:50 |
Originally posted by: Bernd.Laengerich.web.de
Hi everyone,
I encountered a probelm where I want to use a master page from a
library in a template. The master page in the library contains an
embedded image named LogoAPS.png. I can drag the embedded image from
the lib to the template, then the XML says:
<structure>
<property name="name">LogoAPS.png</property>
<property name="libReference">APS.LogoAPS.png</property>
</structure>
this seems correct to me.
Whenever I drag the master page, the image becams red crossed and the
property editor says Reference: APS.png.
Any hints?
I am using 2.2.0 in eclipse.
Bernd
Re: Problem using a library with a template [message #262797 is a reply to message #262685] |
Thu, 06 December 2007 09:23 |
Update:
I just tried 2.2.1 and the problem still exists.
Furthermore, the same situation when correcting the template to use
the embedded images (just reassign the correct embedded image to the
reference) and then registering the template and using it to create a
new design. Images in master page are red crossed and reference set to
"APS.png", which does not exist.
There must be some issue with inheritance, as the generated xml file is:
<page-setup>
<simple-master-page name="APS Portrait A4" id="531"
extends="APS.APS Portrait A4"/>
<simple-master-page name="APS Landscape A4" id="532"
extends="APS.APS Landscape A4"/>
</page-setup>
<list-property name="images">
<structure>
<property name="name">DotLineAPS.png</property>
<property name="libReference">APS.DotLineAPS.png</property>
</structure>
<structure>
</structure>
</list-property>
There is no such reference to APS.png in the xml file.
Bernd
FUDForum. Page generated in 0.03448 seconds
