Preview tab is missing [message #262652] |
Tue, 04 December 2007 20:37  |
Originally posted by: rainer.home.de
I have installed eclipse from deb and then downloaded birt with the
eclipse updater. When I create a birt project and a report, the preview
tab is missing. The .log file:
eclipse.buildId=M20060921-0945
java.version=1.6.0
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.osgi 2 1 2007-12-04 20:22:15.316
!MESSAGE NLS missing message: initializer_error in:
org.eclipse.core.internal.runtime.messages
!ENTRY org.eclipse.osgi 2 1 2007-12-04 20:22:15.317
!MESSAGE NLS missing message: fileInitializer_fileNotFound in:
!MESSAGE NLS missing message: fileInitializer_IOError in:
!MESSAGE NLS missing message: fileInitializer_missingFileName in:
!ENTRY org.eclipse.ui 4 4 2007-12-04 20:22:22.174
!MESSAGE Unable to associate action set with part:
org.eclipse.birt.report.designer.ui.editors.ReportEditor. Action set
org.eclipse.birt.report.designer.ui.previewActionSet not found.
My configuration:
- Debian Testing
- Eclipse 3.2.0
- Birt 2.1.2
Re: Preview tab is missing [message #262658 is a reply to message #262652] |
Tue, 04 December 2007 21:01   |
The preview tab is defined in the
org.eclipse.birt.report.designer.ui.preview plugin.
You don't have this plugin or it is broken.
Snjeza
> java.version=1.6.0
> My configuration:
> - Debian Testing
> - Eclipse 3.2.0 - Birt 2.1.2
Re: Preview tab is missing [message #1389602 is a reply to message #1389359] |
Sat, 28 June 2014 02:55   |
Yep. In Luna, the Preview tab was removed. This was done in favor of the toolbar option. Adding to this, the best way to test your designs how they'll actually look is to use an external browser so you can test across the different browsers. To set this up, go to Window -> Preference -> Report Design -> Preview. On the preview window, select the "use external browser" check box. To specify which browser you want to use, you can navigate to the web browser section under the general tab or by clicking the link below the checkbox. Hope this helps.
Re: Preview tab is missing [message #1390918 is a reply to message #1390889] |
Mon, 30 June 2014 07:20   |
Use the "View Report" drop down in the toolbar to select the output to preview in. The old preview tab was just a straight html output, so if you liked that preview, choose HTML from the drop down list.
FUDForum. Page generated in 0.03490 seconds
