Home » Archived » BIRT » Import packages in script
Import packages in script [message #262297] Wed, 28 November 2007 21:08 Go to next message
I'm wondering if I already did the "importPackage(Packages.....)" in the
"initialize" script tab,
do I still need to do the same import statement everywhere else that I need
to use those imported functions?
eg.
If I have this in the "intialize" script tab in the report
importPackage(Packages.mypackage)
obj = new mypackageCreate( ); //global variable
Do I still need to do the import statment in lets say a report element
expression?
obj.mypackageFunc( ); // calling the imported function in the report element
expression
Maria.
Re: Import packages in script [message #262303 is a reply to message #262297] Thu, 29 November 2007 00:26 Go to previous messageGo to next message
Hi Maria,
in "initialize" method just import the package and in "beforeFactory"
script declare global variable as u want, like following.
in initialize script
in beforeFactory script
now , 'obj' u can use anywhere in report
Shaik
Re: Import packages in script [message #262447 is a reply to message #262303] Thu, 29 November 2007 22:10 Go to previous messageGo to next message
What about in DataSet's script section?
Would packages imported in the "initialize" script tab in the report be
usable in the Data Set's script section?
in beforeOpen script in the Data Set
Maria.
"Shaik" <shaikjaheer@alshaya.com> wrote in message
news:a9b2cb7cc2709568979b115da0fb738b$1@www.eclipse.org...
> Hi Maria,
> Shaik
Re: Import packages in script [message #262471 is a reply to message #262303] Fri, 30 November 2007 09:29 Go to previous message
Originally posted by: calvinwongkh_delete.this.thanks_.yahoo.com
Hi Shaik,
If I defined a globalized function in "initialize" that uses a class in
the package, do I need to declare the class into the the global variable
as well?
Calvin
Shaik wrote:
> Hi Maria,
> Shaik
Previous Topic:Rendering node lists.
Next Topic:Setting BIRT_HOME
Current Time: Wed Jul 02 10:53:27 EDT 2025
Powered by FUDForum. Page generated in 0.08822 seconds
