Home » Archived » BIRT » Problem While Rendering Report from Report design file
Problem While Rendering Report from Report design file [message #261645] |
Mon, 19 November 2007 12:18 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: joyeetag.gmail.com
I am using Birt 2.1 runtime and Birt report engine APIs while integrating
Birt with our own Portlet Appliation deployed in JBoss 4.0.5.
I am trying to generate PDF report from my application.
But while Coming till Runing and Rendering the Report(task.run())
its getting an error like :
org.eclipse.birt.report.engine.api.EngineException:
Report engine fails to create extension to handle this request.
I have itext1.3 jar in my classpath as well as my plugin directory.
The log as follows:
17:05:55,453 INFO [STDOUT] GetRealPath :
D:\work\jboss\server\default\.\deploy\repro-template-portlet .war\repro\temp\latest2.rptdesign
17:07:59,406 ERROR [STDERR]
org.eclipse.birt.report.engine.api.EngineException: Report engine fails to
17:07:59,421 ERROR [STDERR] at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.cre ateContentEmitter(RunAndRenderTask.java:104)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:155)
com.anshinsoft.repro.dashboard.template.birt.BirtReportGener ator.generateReport(BirtReportGenerator.java:200)
17:07:59,437 ERROR [STDERR] at
com.anshinsoft.repro.enterprise.ReportGenerator.generateRepo rts(ReportGenerator.java:173)
com.anshinsoft.repro.enterprise.ReportGenerator.generateRepo rts(ReportGenerator.java:196)
com.anshinsoft.repro.dashboard.template.action.GenerateRepor tEventAction.execute(GenerateReportEventAction.java:184)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
java.lang.reflect.Method.invoke(Method.java:597)
com.opensymphony.xwork2.DefaultActionInvocation.invokeAction (DefaultActionInvocation.java:399)
com.opensymphony.xwork2.DefaultActionInvocation.invokeAction Only(DefaultActionInvocation.java:262)
com.opensymphony.xwork2.DefaultActionInvocation.invoke(Defau ltActionInvocation.java:224)
org.apache.struts2.portlet.interceptor.PortletPreferencesInt erceptor.intercept(PortletPreferencesInterceptor.java:102)
com.opensymphony.xwork2.DefaultActionInvocation$2.doProfilin g(DefaultActionInvocation.java:219)
com.opensymphony.xwork2.DefaultActionInvocation$2.doProfilin g(DefaultActionInvocation.java:218)
com.opensymphony.xwork2.util.profiling.UtilTimerStack.profil e(UtilTimerStack.java:455)
com.opensymphony.xwork2.DefaultActionInvocation.invoke(Defau ltActionInvocation.java:216)
17:07:59,453 ERROR [STDERR] at
com.opensymphony.xwork2.interceptor.DefaultWorkflowIntercept or.doIntercept(DefaultWorkflowInterceptor.java:213)
com.opensymphony.xwork2.interceptor.MethodFilterInterceptor. intercept(MethodFilterInterceptor.java:86)
17:07:59,468 ERROR [STDERR] at
com.opensymphony.xwork2.validator.ValidationInterceptor.doIn tercept(ValidationInterceptor.java:150)
org.apache.struts2.interceptor.validation.AnnotationValidati onInterceptor.doIntercept(AnnotationValidationInterceptor.j
com.opensymphony.xwork2.interceptor.ConversionErrorIntercept or.intercept(ConversionErrorInterceptor.java:123)
17:07:59,484 ERROR [STDERR] at
com.opensymphony.xwork2.interceptor.ParametersInterceptor.in tercept(ParametersInterceptor.java:161)
com.opensymphony.xwork2.interceptor.StaticParametersIntercep tor.intercept(StaticParametersInterceptor.java:105)
17:07:59,500 ERROR [STDERR] at
org.apache.struts2.interceptor.CheckboxInterceptor.intercept (CheckboxInterceptor.java:83)
org.apache.struts2.interceptor.FileUploadInterceptor.interce pt(FileUploadInterceptor.java:207)
com.opensymphony.xwork2.interceptor.ModelDrivenInterceptor.i ntercept(ModelDrivenInterceptor.java:74)
17:07:59,515 ERROR [STDERR] at
com.opensymphony.xwork2.interceptor.ScopedModelDrivenInterce ptor.intercept(ScopedModelDrivenInterceptor.java:127)
org.apache.struts2.interceptor.ProfilingActivationIntercepto r.intercept(ProfilingActivationInterceptor.java:107)
17:07:59,531 ERROR [STDERR] at
org.apache.struts2.interceptor.debugging.DebuggingIntercepto r.intercept(DebuggingInterceptor.java:206)
com.opensymphony.xwork2.interceptor.ChainingInterceptor.inte rcept(ChainingInterceptor.java:115)
com.opensymphony.xwork2.interceptor.I18nInterceptor.intercep t(I18nInterceptor.java:143)
17:07:59,546 ERROR [STDERR] at
com.opensymphony.xwork2.interceptor.PrepareInterceptor.inter cept(PrepareInterceptor.java:115)
org.apache.struts2.interceptor.ServletConfigInterceptor.inte rcept(ServletConfigInterceptor.java:170)
com.opensymphony.xwork2.interceptor.AliasInterceptor.interce pt(AliasInterceptor.java:123)
17:07:59,562 ERROR [STDERR] at
com.opensymphony.xwork2.interceptor.ExceptionMappingIntercep tor.intercept(ExceptionMappingInterceptor.java:176)
org.apache.struts2.impl.StrutsActionProxy.execute(StrutsActi onProxy.java:50)
org.apache.struts2.portlet.dispatcher.Jsr168Dispatcher.servi ceAction(Jsr168Dispatcher.java:427)
org.apache.struts2.portlet.dispatcher.Jsr168Dispatcher.proce ssAction(Jsr168Dispatcher.java:281)
com.liferay.portal.kernel.servlet.PortletServlet.service(Por tletServlet.java:101)
javax.servlet.http.HttpServlet.service(HttpServlet.java:810)
17:07:59,578 ERROR [STDERR] at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:252)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:173)
org.apache.catalina.core.ApplicationDispatcher.invoke(Applic ationDispatcher.java:672)
org.apache.catalina.core.ApplicationDispatcher.doInclude(App licationDispatcher.java:574)
org.apache.catalina.core.ApplicationDispatcher.include(Appli cationDispatcher.java:499)
com.liferay.portlet.CachePortlet._invoke(CachePortlet.java:3 52)
com.liferay.portlet.CachePortlet.processAction(CachePortlet. java:174)
com.liferay.portal.action.LayoutAction.processPortletRequest (LayoutAction.java:306)
com.liferay.portal.action.LayoutAction.processActionRequest( LayoutAction.java:334)
com.liferay.portal.action.LayoutAction.execute(LayoutAction. java:121)
org.apache.struts.action.RequestProcessor.processActionPerfo rm(RequestProcessor.java:431)
org.apache.struts.action.RequestProcessor.process(RequestPro cessor.java:236)
com.liferay.portal.struts.PortalRequestProcessor.process(Por talRequestProcessor.java:157)
17:07:59,593 ERROR [STDERR] at
org.apache.struts.action.ActionServlet.process(ActionServlet .java:1196)
org.apache.struts.action.ActionServlet.doPost(ActionServlet. java:432)
javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
com.liferay.portal.servlet.MainServlet.callParentService(Mai nServlet.java:280)
com.liferay.portal.servlet.MainServlet.service(MainServlet.j ava:534)
com.liferay.filters.secure.SecureFilter.doFilter(SecureFilte r.java:144)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:202)
com.liferay.portal.servlet.filters.virtualhost.VirtualHostFi lter.doFilter(VirtualHostFilter.java:136)
17:07:59,609 ERROR [STDERR] at
org.apache.catalina.core.ApplicationDispatcher.processReques t(ApplicationDispatcher.java:463)
org.apache.catalina.core.ApplicationDispatcher.doForward(App licationDispatcher.java:398)
org.apache.catalina.core.ApplicationDispatcher.forward(Appli cationDispatcher.java:301)
com.liferay.portal.servlet.FriendlyURLServlet.service(Friend lyURLServlet.java:126)
com.liferay.filters.strip.StripFilter.doFilter(StripFilter.j ava:95)
17:07:59,625 ERROR [STDERR] at
com.liferay.filters.compression.CompressionFilter.doFilter(C ompressionFilter.java:116)
com.liferay.filters.doubleclick.DoubleClickFilter.doFilter(D oubleClickFilter.java:138)
com.liferay.portal.servlet.filters.layoutcache.LayoutCacheFi lter.doFilter(LayoutCacheFilter.java:170)
com.liferay.portal.servlet.filters.autologin.AutoLoginFilter .doFilter(AutoLoginFilter.java:106)
17:07:59,640 ERROR [STDERR] at
org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(Repl yHeaderFilter.java:96)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:178)
org.jboss.web.tomcat.security.SecurityAssociationValve.invok e(SecurityAssociationValve.java:175)
org.apache.catalina.authenticator.AuthenticatorBase.invoke(A uthenticatorBase.java:432)
org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccCo ntextValve.java:74)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:126)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:105)
org.jboss.web.tomcat.tc5.jca.CachedConnectionValve.invoke(Ca chedConnectionValve.java:156)
17:07:59,656 ERROR [STDERR] at
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:107)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:148)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:869)
org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:664)
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:527)
org.apache.tomcat.util.net.MasterSlaveWorkerThread.run(Maste rSlaveWorkerThread.java:112)
17:07:59,656 ERROR [STDERR] at java.lang.Thread.run(Thread.java:619)
17:13:17,671 ERROR [STDERR]
org.eclipse.birt.report.engine.api.EngineException: Error happened while
running the report
17:13:17,671 ERROR [STDERR] at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:198)
17:13:17,687 ERROR [STDERR] at
17:13:17,703 ERROR [STDERR] at
17:13:17,703 ERROR [STDERR] at java.lang.Thread.run(Thread.java:619)
17:13:17,718 ERROR [STDERR] Caused by:
17:13:17,718 ERROR [STDERR] at
17:13:17,718 ERROR [STDERR] ... 183 more
Please suggest what possibly be wrong?
Thanks in Advance.
Joyeeta
Re: Problem While Rendering Report from Report design file [message #261781 is a reply to message #261645] |
Tue, 20 November 2007 15:40 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Joyeeta,
Can you post your code?
Jason
> integrating Birt with our own Portlet Appliation deployed in JBoss 4.0.5.
> The log as follows:
> running the report
> Thanks in Advance.
> Joyeeta
Current Time: Sat Jul 13 16:45:08 GMT 2024
Powered by FUDForum. Page generated in 0.03337 seconds
