Comparators [message #261261] |
Mon, 12 November 2007 19:06 |
Originally posted by: thomas.cintegrity.com
In our design there is a class which has both a parent association to
the same class and a predecessor association to this class. This
creates an outline type structure like:
1.
1.1
1.2
2.
2.1
2.2
where 1.1 is a predecessor to 1.2, both 1.1 and 1.2 are parented to 1.
and 1.1 has a predecessor of 1. Likewise for the 2* entries and 1. is
the predecessor of 2. Links are navigatible in either direction. In
normal operation, a Comparator for this class provides for sort order
based on these relationships.
Is there any way to utilize this Comparator to provide sort order in a
BIRT report? I'm a bit puzzled as to how to achieve it with straight
SQL on the persisted class.
Re: Comparators [message #261497 is a reply to message #261261] |
Thu, 15 November 2007 17:13 |
Thomas,
Can you call your class from the sort expression and return a numeric
value for the level? If you can do that the sort expression can be set
to ascending and lower numbers will be presented first. I am not
certain this is really what you are looking for.
Jason
> 1.
> 1.1
> 1.2
> 2.
> 2.1
> 2.2
FUDForum. Page generated in 0.03407 seconds
