Home » Archived » BIRT » retrieve a message from JDBC ?
retrieve a message from JDBC ? [message #260480] Sat, 03 November 2007 09:54 Go to next message
Originally posted by: aaa.aaa.it
Hi!
My report uses a store procedure (in postgres) which may raise some errors.
Using webviewer I see no error message when an error is raised.
I can see it only by log.
Is it possible to see it on the web page? Something to configure for
that goal?
Thank you,
Nicola
Re: retrieve a message from JDBC ? [message #260515 is a reply to message #260480] Mon, 05 November 2007 00:53 Go to previous message
Tianli Zhang is currently offline Tianli ZhangFriend
Hi Nicola
I think you are using the frameset model to run the report, please try
preview model like the following url:
http://localhost:8080/birt/preview?__report=test.rptdesign
you can see the error log when preview.
FYI: how to use the Report Web Viewer:
http://www.eclipse.org/birt/phoenix/deploy/viewerUsage.php
Previous Topic:Plotting numerical data on x-axis with LineChart?
Next Topic:Stacked bar chart
Current Time: Thu Dec 26 13:13:55 GMT 2024
Powered by FUDForum. Page generated in 0.02647 seconds
