plugin and tool mentors [message #25674] |
Tue, 19 December 2006 14:28  |
Originally posted by: claude.aubryconseil.com
I had a process including tool mentors. I made a separated plugin -for
the tool and the tool mentors- which references the base process. I want
to re-associate tool mentors to the tasks. The solution that I found
requires to create in the tool plugin new tasks which extend those of
the basic process and then to associate the tool mentors to them. I have
also to create categories for the publication of these tasks.
Is there a simpler solution?
Claude
Re: plugin and tool mentors [message #26258 is a reply to message #26176] |
Wed, 10 January 2007 05:13  |
It would be much easier if the dependence between tool mentors and tasks
was reversed, allowing making the link from the tool mentor.
Claude
Peter Haumer a écrit :
> Yes, that is the best way to do it. If you want to decouple your tool
> mentors from your content you need such an indirection.
Re: plugin and tool mentors [message #574490 is a reply to message #25674] |
Tue, 09 January 2007 12:58  |
Thanks and best regards,
Peter Haumer.
____________________________________________________________ __
PETER HAUMER
IBM | Eclipse Process Framework Committer
"Claude Aubry" <claude@aubryconseil.com> wrote in message
news:em9egf$6fp$1@utils.eclipse.org...
>I had a process including tool mentors. I made a separated plugin -for the
>tool and the tool mentors- which references the base process. I want to
>re-associate tool mentors to the tasks. The solution that I found requires
>to create in the tool plugin new tasks which extend those of the basic
>process and then to associate the tool mentors to them. I have also to
> Claude
Re: plugin and tool mentors [message #574588 is a reply to message #26176] |
Claude
FUDForum. Page generated in 0.23577 seconds
