| JDT HELP [message #259624] |
Mon, 20 April 2009 02:02  |
Hello Guys,
I am stuck in my project and need an urgent help. I have to parse my
Java project(the java packages in the project as well as the java source
files inside the packages) and build a tree from it and show the tree in
an ecclipse view. What am doing is this:
I have some information from a server and i have to compare those results
to the name of the nodes in my project(the ast nodes from the java source
files) and if i find a match, then i must show them(nodes) as a tree in a
view.
My problem now is how i should parse the Java source files. I don't know
how to do it. I have read this tutorial:
http://www.eclipse.org/articles/article.php?file=Article-Jav aCodeManipulation_AST/index.html
but it doesn't give me much idea about the starting point and also got
stuck there. Am asking if someone can help me to do it.
At the moment i have this class:
public class TestingBindings {
protected CompilationUnit parse(ICompilationUnit unit) {
ASTParser parser = ASTParser.newParser(AST.JLS3);
parser.setKind(ASTParser.K_COMPILATION_UNIT);
parser.setSource(unit); // set source
parser.setResolveBindings(true); // we need bindings later on
return (CompilationUnit)parser.createAST(null /* IProgressMonitor
*/); // parse
public ICompilationUnit findProject(){
IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
// "yourplugins" is a project name
IProject project = root.getProject("yourplugins");
if (project.exists() && !project.isOpen())
try {
project.open(null /* IProgressMonitor */);
} catch (CoreException e1) {
e1.printStackTrace();
IJavaProject javaProject = JavaCore.create(project);
IType lwType = null;
try {
//"yplugins" is a package name
"Activator" is a class name
lwType = javaProject.findType("yplugins.Activator");
} catch (JavaModelException e) {
e.printStackTrace();
ICompilationUnit lwCompilationUnit = lwType.getCompilationUnit();
return lwCompilationUnit;
After i created this class, i am just stuck i don't know how to go further
and process the projects and packages and the source files.
IMPORTANT:
I want to be able to parse a project and inside the project all the
packages and inside the packages all the classes
So please help me to understand what i should do and how i should do it. I
have spent much weeks on the web looking for answers but unable to find a
tutorial for a beginner like me. I search the JDT documentation but
couldn't figure out what to use since there are so many methods and also
is not suitable for beginner like me. Please help.
Thanks for all your help.
| Re: JDT HELP [message #259662 is a reply to message #259624] |
Tue, 21 April 2009 11:33  |
Eddy,
Assuming this question is about the AST side not the view side.
> how to do it.
With "parse the Java source files" you probably mean: "call the ASTParser
to obtain an AST", right?
So you have a method to find an ICompilationUnit and another one that
converts an ICompilationUnit (source) into a CompilationUnit (parsed AST).
That sounds like you have the solution at hand. So, what is the missing
link here? org.eclipse.jdt.core.dom.CompilationUnit is the root of the
parsed AST. If you have that you need no more parsing.
If your question is really about parsing, the answer would be
CompilationUnit unit = parse(findProject());
best
Stephan
FUDForum. Page generated in 0.04413 seconds
