Home » Language IDEs » Java Development Tools (JDT) » Get Tab Size from Preferences
Get Tab Size from Preferences [message #259549] Wed, 15 April 2009 00:27 Go to next message
Nikolay Georgiev is currently offline Nikolay GeorgievFriend
I suppose this is the right group to ask the question.
I'm trying to get the Tab size in java source files, which is set by the
current code formatter. In the XML file of the formatter it has the key:
"org.eclipse.jdt.core.formatter.tabulation.size"
And I suppose that it is contained in some PreferenceStore, but calling
PlatformUI.getPreferenceStore().getInt("org.eclipse.jdt.core.formatter.tabulation.size ")
does not return the value.
Do you know how can I get the value?
Thank You!
Nikolay
Re: Get Tab Size from Preferences [message #259563 is a reply to message #259549] Wed, 15 April 2009 10:31 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
Nikolay wrote:
> Hello,
> the current code formatter. In the XML file of the formatter it has
> the key:
The Platform UI plug-in knows nothing about JDT and hence you won't find
it there.
I suggest to take a look at
org.eclipse.jdt.internal.corext.util.CodeFormatterUtil.getTa bWidth(IJavaProject).
Dani
> Thank You!
> Nikolay
Re: Get Tab Size from Preferences [message #259588 is a reply to message #259563] Thu, 16 April 2009 20:32 Go to previous message
Wow, Thank you Dani! :)) It worked perfectly :P
Previous Topic:Extending Java Search Functionality From the Result View Toolbar
Next Topic:How to add superinterface to IType
Current Time: Mon Jan 13 20:47:34 GMT 2025
Powered by FUDForum. Page generated in 0.02861 seconds
