Home » Eclipse Projects » Eclipse Platform » Worker thread question
Worker thread question [message #259542] Thu, 08 July 2004 09:38 Go to next message
Originally posted by: weberjn.yahoo.com
The situation: RCP application needs to fill a dialogue from a database
via hibernate. Getting the data needs about two seconds, in this time
there is no gui update and the gui looks very hackly.
So, I want to have the data loaded by a second thread.
One option were that this thread fills the data into the gui with
display.syncExec(
new Runnable() {
public void run(){
label.setText(text);
( http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/faq.html#uithread)
But what is the main thread to do in the meantime?
It should be blocked, so the user cannot do anything (i.e. leave the
dialog while the data is still loading), but also it should update the
gui. How can this be done?
parallel
begin worker thread
load data
copy data into gui
set ready semaphore
end worker thread
begin gui thread
while not (ready semaphore)
update gui
end worker thread
end parallel
I have no idea how to transform the gui thread pseudo code into real code,
i.e. how to have eclipse update the gui and at the same time block user
input.
Thanks for links and hints,
Juergen
Re: Worker thread question [message #259759 is a reply to message #259542] Thu, 08 July 2004 15:48 Go to previous message
Originally posted by: john.eclipsefaq.org
To keep the UI alive (but blocked) while running a process in another
thread, use the IProgressService:
PlatformUI.getWorkbench().getProgressService().busyCursorWhi le(runnable).
From within that runnable, you can post updates to the UI using
asyncExec or syncExec.
However, if you are already within the context of a modal dialog, you
may not need to block the user in this way. You can just create a
background Job (org.eclipse.core.runtime.jobs.Job), that will fetch the
data from the server and post periodic updates to the UI (for example
using a UIJob). This allows you to keep the UI alive and interactive
while the background work goes on.
> display.syncExec(
> new Runnable() {
> public void run(){
> parallel
> begin worker thread
> load data
> copy data into gui
> set ready semaphore
> end worker thread
> begin gui thread
> update gui
> end worker thread
> end parallel
> input.
> Juergen
Previous Topic:eclipse current CVS (after 3.0 final)
Next Topic:Java files not getting compiled. Eclipse 3.0
Current Time: Wed Jan 15 07:12:29 GMT 2025
Powered by FUDForum. Page generated in 0.04038 seconds
