Home » Eclipse Projects » Eclipse Platform » How to customize help topics in org.eclipse.help plugin?
How to customize help topics in org.eclipse.help plugin? [message #259488] Thu, 08 July 2004 07:17 Go to next message
Originally posted by: gkaviyarasu.crimsonlogic.co.in
I've developed one plugin to call the workbench help support. I used
org.eclipse.help.toc extension point in my plugin. And i call this plugin
when a menu is clicked. I call the following code snippet in run method of
my action class.
That plugin opens the help and i m getting my help topics appended to the
workbench help.
Here is the code to call the workbenchhelp:
WorkbenchHelp.displayHelp();
My Question is:
Is it possible to remove some in-built help topics from the workbench
help?
I needed this to display ONLY my project related help contents, not
cluttered with eclipse help.
Thanks in advance,
Kaviyarasu.
Re: How to customize help topics in org.eclipse.help plugin? [message #259785 is a reply to message #259488] Thu, 08 July 2004 16:33 Go to previous message
Konrad Kolosowski is currently offline Konrad KolosowskiFriend
Either remove unwanted documentation plug-ins from you product, or do not
add them if building on top of RCP.
Another solution is to define map plug-ins Eclipse .*.doc.* plug-ins to
disabled UI capabilties.
Konrad
"Ganapathy Kaviyarasu" <gkaviyarasu@crimsonlogic.co.in> wrote in message
news:ccise8$4en$1@eclipse.org...
> my action class.
> workbench help.
> My Question is:
> help?
> Thanks in advance,
> Regards
> Kaviyarasu.
Previous Topic:Java files not getting compiled. Eclipse 3.0
Next Topic:Eclipse won't start: "No application id has been found"
Current Time: Thu Dec 26 14:50:59 GMT 2024
Powered by FUDForum. Page generated in 0.03450 seconds
