Home » Archived » BIRT » Re: Archive root folder cant be removed
Re: Archive root folder cant be removed [message #259447] Thu, 25 October 2007 13:13 Go to next message
Krzysztof Daniel is currently offline Krzysztof DanielFriend
Member
Hello
The issue has been discussed in the following thread:
http://dev.eclipse.org/newslists/news.eclipse.birt/msg18067. html
As far as I have noticed there are all necessary information :)
Also, birt has its own newsgroup eclipse.birt. I have crossposted my
answer. So please use eclipse.birt for birt problems ;-).
Chris
> We are using birt 2.1.2 version. While generating the report using the
> report viewer we are encountered with the error
> " org.eclipse.birt.report.service.api.ReportServiceException:A rchive root
> folder cant be removed". This error occurs only when we terminate a
> report generation process and try generating again the same report.
Re: Archive root folder cant be removed [message #259612 is a reply to message #259447] Fri, 26 October 2007 09:45 Go to previous message
Originally posted by: vikram4178.gmail.com
Hi Chris,
Thanks for your reply. I checked the link mentioned and i think there it
is concluded that this problem has been addressed in the 2.2 version and
not in earlier versions. Please confirm me if i am right.
Thanks again
-Vikram S
Previous Topic:What are the jars i want add for deployed BIRT war file
Next Topic:Chart in Report output pdf is not displayed
Current Time: Thu Dec 26 14:35:45 GMT 2024
Powered by FUDForum. Page generated in 0.02578 seconds
