Home » Eclipse Projects » Eclipse Platform » How to jump into function implementation
How to jump into function implementation [message #259430] Wed, 07 July 2004 20:21 Go to next message
Originally posted by: bpirvali.symantec.com
I am new to eclipse.
I program normally against a set of interfaces instead of using classes.
When I try to jump into a function implementation, I get redirected into
interface definition instead of jumping into implementor of the interface.
Is there a way to jump function body instead of the interface definition?
Behzad
Re: How to jump into function implementation [message #259460 is a reply to message #259430] Thu, 08 July 2004 00:22 Go to previous messageGo to next message
Originally posted by: linnet.nospam.users.sourceforge.net
Hi Behzad,
Yes, it's really annoying, isn't it?
If you use Eclipse 3.0, you could press Ctrl+T (or Navigate -> Quick
Type Hierarchy) to get a popup type hierarchy from which you can jump to
the implementation class.
Alternatively, you can use a plugin I wrote for the exact purpose of
jumping to implementations (since I was also annoyed). You can find it
here: http://eclipse-tools.sourceforge.net/implementors. Be aware that
there are currently different versions of the plugin for different
versions of Eclipse. I should be releasing version 0.0.14 really soon
now with support for both Eclipse 2.1 and 3.0.
Jesper
Behzad Pirvali wrote:
> Behzad
Re: How to jump into function implementation [message #259511 is a reply to message #259460] Thu, 08 July 2004 04:15 Go to previous messageGo to next message
Hi Jesper,
Thanks a lot for your help. I am using Eclipse 3.0 and Ctrl+T works for me.
How did you find this?
I was not able to find it under keyboard shortcuts or any where else in the
help!
Do you know whether Eclipse has an advanced multi-entry clipboard?
Behzad
"Jesper Kamstrup Linnet" <linnet@nospam.users.sourceforge.net> wrote in
message news:ccii5a$jiq$2@eclipse.org...
> Hi Behzad,
> Best regards,
> Jesper
> > Hi,
interface.
definition?
> > Thanks,
> > Behzad
Re: How to jump into function implementation [message #259596 is a reply to message #259511] Thu, 08 July 2004 08:46 Go to previous messageGo to next message
Hi Behzad,
Have you checked out the keyboard shortcuts quick reference at
http://eclipse-tools.sourceforge.net/shortcuts.html ? I haven't yet
"upgraded" it to the final version of 3.0, but it should more or less be
correct (apart from the fact - I just realized - that the legend for
Ctrl+T is "Open Hierarchy"). I guess an update is coming up... :-)
Regarding the multi-entry clipboard: No, Eclipse uses the regular
clipboard provided by the operating system (AFAIK).
Jesper
bpirvali wrote:
> Hi Jesper,
> help!
> Behzad
> > Hi Behzad,
> > Best regards,
> > Jesper
> > > Hi,
> interface.
> definition?
> > > Thanks,
> > > Behzad
Re: How to jump into function implementation [message #259809 is a reply to message #259460] Thu, 08 July 2004 14:21 Go to previous messageGo to next message
Originally posted by: neil.neil.swingler.name
Hi Jesper,
I'm afraid that by letting the world know about Ctrl+T, you have made your
wonderful plugin dispensible. Still the call heirarchy lives on:-)
- Neil Swingler
> Hi Behzad,
> Best regards,
> Jesper
> > Hi,
interface.
definition?
> > Thanks,
> > Behzad
Re: How to jump into function implementation [message #259817 is a reply to message #259809] Thu, 08 July 2004 14:46 Go to previous messageGo to next message
You may be right, but I cannot help being a nice guy... :-) At least
it's nice to know that some people call it wonderful! (I like it myself,
too :-).
/Jesper
Neil Swingler wrote:
> Hi Jesper,
> - Neil Swingler
>>Hi Behzad,
>>Best regards,
>>Jesper
>>>Hi,
> interface.
> definition?
>>>Thanks,
>>>Behzad
Re: How to jump into function implementation [message #259869 is a reply to message #259596] Thu, 08 July 2004 16:48 Go to previous message
Hi Jesper,
Great site for short cuts,
Thanks so much,
Behzad
message news:ccjfn7$arf$1@eclipse.org...
> Hi Behzad,
> Best regards,
> Jesper
> bpirvali wrote:
> > Hi Jesper,
me.
the
> > help!
> > Thanks,
> > Behzad
> > > Hi Behzad,
to
> > > Best regards,
> > > Jesper
> > > > Hi,
classes.
into
> > interface.
> > definition?
> > > > Thanks,
> > > > Behzad
Previous Topic:ant syntax color problem
Next Topic:eclipse close lifttime
Current Time: Tue Oct 28 02:06:09 EDT 2025
Powered by FUDForum. Page generated in 1.05516 seconds
